Hot Water Fuse/switch?? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 05:35 PM   #1
Hot water fuse/switch??
Hi,
I recently replaced a blown hot water system heating element (the copper peices were visible burnt); However i'm not sure how to replace the fuse in the ceramic fuse holder, it's a combined fuse holder/switch in the meter box that has a black knob labelled 'Pull OFF Push ON'. I have tried with some force to completely remove it but can't get it out (don't want to break it). Wondering if anyone has come across these before (I know it's a fuse holder because I can see the fuse wire when it's pulled in the out position, just cant get it completely out).
Pic:
Uploaded with ImageShack.us
Wozz is offline   Reply With Quote
Old 08-16-2011, 06:31 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Looks like porceline. Try wiggling it and see if it comes out.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-16-2011, 07:00 PM   #3
Yeah that's right it's like a ceramic. Wiggling was the first thing i'd tried, it does move around a bit, have tried pushing/pulling, sideways etc.
If no one knows I might just have to use brute force! If I break it, it's probably due for an upgrade to a circuit breaker anyway (unless anyone has seen one before and knows for sure how to remove it 'correctly')
Old 08-16-2011, 07:28 PM   #4
electures's Avatar
SOunds like it's time for brute force. "If it don't move force it. If it breaks it needed replacement anyway." Good luck!
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
