Hot Water Electric Hook Up - Electrical - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 09:47 PM   #1
hot water electric hook up
My hot water heater has a black,yellow and blue wiring, but the power coming into is Black,gray and pink. How do I wire ? Thanks
rdflowers is offline   Reply With Quote
Old 12-11-2010, 02:06 AM   #2
" Euro " electrician
frenchelectrican's Avatar
I can tell this is not a typical north Americian connection and are you in UK ??
Let us know which area you are in so I can able tell you the correct conferation.
Merci.
Marc
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Trouble With Electric Hot Water Heater whitedavidp Electrical 7 04-06-2009 04:26 PM
