Hot Vs. Neutral On Chandelier - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2013, 11:06 PM   #1
Rewards Points: 398
Hot vs. Neutral on chandelier
I recently inherited a dining room chandelier from my grandparents. It was nicer then the one I had so I took it. If I had to guess, I would say it's from early / mid 90s.
When I unhooked it from his place I checked and there was a sticker that marked the neutral wire.
When I got home and started installing, the sticker fell off while my head was turned.
Both wires are gold all the way to the base. One has writing on it but it's just the brand name. The other side I found a small amount of tape residue from what looks like the old sticker but I'm no way sure.
Any suggestions so I can hook it up correctly? I don't want to cross the wires although from what I read somewhere it should still light regardless.
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 10-17-2013, 11:12 PM   #2
Rewards Points: 746
Is one wire "ribbed"? If so, that should be the neutral.
You can also check with a meter. The outside base of the bulb, the threads, should be the neutral side.
AandPDan is offline   Reply With Quote
Old 10-17-2013, 11:17 PM   #3
Rewards Points: 150
One side of the wire should be ribbed. That's your neutral. To be sure, check continuity between socket shell and wire.
romex1220 is offline   Reply With Quote
Old 10-18-2013, 08:54 AM   #4
Rewards Points: 398
Thanks for the reply - I looked and couldn't find a ribbed side. I will check with a multi-meter this afternoon. I assume red to hot, black to neutral - correct?
If the wiring is incorrect I will get a negative reading I assume - right?
Old 10-18-2013, 09:25 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
Where did you come up with red and black?
If you do not have a rib, then the side with the writing.
To test for the correct wire, connect an ohm meter to one lead, and check the tab inside the light socket.
I should have clarified, the tab will be the hot and the shell will be the neutral.
Old 10-18-2013, 09:38 AM   #6
PoleCat's Avatar
Rewards Points: 1,646
No white wire up there?
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-18-2013, 10:18 AM   #7
Rewards Points: 398
Sorry - should have clarified. My multi-meter had red and black (positive / negative) prongs. When I connect the prongs to the socket and turn it to the ohm setting - does t matter which prong is on which part of the socket?
When the meter is on the Ohm setting, what should I be reading that would indicate correct or incorrect wiring?
Old 10-18-2013, 10:25 AM   #8
Rewards Points: 774
Use the ohm feature of your multimeter, red black makes no difference.
One lead (say red) to the shell of the lamp holder and then the other lead (black but makes no difference) to one wire then the other. Needle of MM goes to "0" zero you have it, if it is digital then a "0" reading.
Know A Little is offline   Reply With Quote
The Following User Says Thank You to Know A Little For This Useful Post:
adgjqetuo (10-18-2013)
Old 10-18-2013, 10:37 AM   #9
Rewards Points: 398
Thanks !
It is digital, I will give it a shot tonight and see what happens.
Hopefully I won't have to take it apart again
Just out of curiosity, what is the danger in having them switched? I know the older non-polarized plugs can be switched and they still operate.
Old 10-18-2013, 10:59 AM   #10
Rewards Points: 342
if you happen to have the hot wire attached to the screw shell & you touch the shell , it want be nice i might say. that why it needs to be correct as others have said.you may look like this smile when you touch it.
circuitman is offline   Reply With Quote
Old 10-19-2013, 09:37 AM   #11
PoleCat's Avatar
Do NOT use the ohm meter on a live circuit. Use AC volt setting.
Old 10-19-2013, 11:14 AM   #12
Rewards Points: 774
My initial thought was, WELL DUH......But on second thought, many of us have made that mistake at least once.
Philly Master (10-19-2013)
Old 10-19-2013, 12:34 PM   #13
Philly Master's Avatar
Rewards Points: 516
LOL i use an AUTOMATIC Fluke model .......
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 10-19-2013, 02:57 PM   #14
Rewards Points: 774
40 some years ago I blew the fuse in an amp-probe clamp on doing just that. Having no fuse I took the foil from the pack of Marlboros and made a FUSE (?) turned around and did the exact same thing.
As hard as I tried I could not get the smoke back in that thing.
Old 10-22-2013, 07:41 AM   #15
Rewards Points: 398
I didn't know the circuit couldn't be live. I put the meter on ohm and hit the switch and used the prongs on the lamp contacts. It read 0 from what I could tell. Should I redo this test now with the switch off?
Common Neutral in Jct Box??? PastorKramer Electrical 5 11-20-2012 07:10 AM
Need Neutral Connections - Installing Subpanel ctlu008 Electrical 10 01-01-2012 08:54 AM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 02:36 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 02:23 AM
