Hello all...
I am hoping this will be quick and easy scenerio here.
I need to run a 50 to 75 foot 8/3 w_ground from main house panel to outside subpanel box.
I was planning on using THHN indoor wire. I is going to run through the garage, into basement and near furnance. I am punching a hole through foundation and need 10 to 15 feet out past wall to subpanel box. I believe the wire is OK in the ceiling by itself, but not sure if I should use EMT, PVC or the Non-Metallic Liquid-Tight Flexible Conduit?
The subpanel will have a 50 amp gfci and the main panel in house will have 50 regular breaker. From the subpanel I was going to run 10 to 15 feet connections to the hottub. The dealer is supplying me the subpanel. The code in my area is subpanel needs to be more than 5 feet from tub but no more than 10 feet (but visible)
Could I use the same flexible pipe?
http://www.lowes.com/pd_69860-295-5...rd_nbr|0||p_product_quantity_sold|1&facetInfo=
Also, the hole in the foundation of the house...should there be some kind of union? I have no idea what this is or looks like....
Besides all this...I am comfortable running and hooking up the cabling/breakers. Thanks for the help.
