Hot Tub Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2015, 02:22 PM   #1
Rewards Points: 2
Hot tub wiring
I am moving to a new residence. I want to install my 220v hot tub. I was thinking of using 6/3 Romex NM-B from my service panel, through my garage wall and through my crawl space directly to the hot tub disconnect breaker box. This is about 75ft. Then from the breaker box I am gonna run 6/3 Romex UFB in flex conduit to my hot tub. This run will be about 15ft. I will be securing the wiring in the crawl space to the floor joices using electrical staples. I will also be securing the conduit using strapping. Does anyone have any better ideas.
Timf4223 is offline   Reply With Quote
Old 08-24-2015, 02:59 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 3,026
Hot tub wiring
Is the 15 feet of flex outside the building? If so, the UF is not compliant. You need an insulated ground. Run THWN.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
Jim Port (08-24-2015), Oso954 (08-24-2015)
Old 08-24-2015, 04:01 PM   #3
Oso954's Avatar
Rewards Points: 3,086
Hot tub wiring
In California the 15ft would not be allowed. For hot tubs here, you are only allowed 6ft of liquidtite between the wall of the tub and the connection point, in this case, your disconnect/breaker box. Additional footage under the tub is permissible. So I would be running PVC conduit to a point at least near the tub, if not under it, before transitioning to liquidtite.
Your location can impact the response you get, because of local amendments to the codes.
Oso954 is offline   Reply With Quote
Old House Wiring Traycam Electrical 14 01-03-2015 09:31 PM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
