Hot Tub Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 07:39 PM   #1
Rewards Points: 14
Hot tub wiring
I'm about to buy a hot tub, but want to make sure our wiring is correct before I buy anything. The previous owners of the house had a hot tub but took it with them. It was definitely wired for 220(3 wire w/ground 8 or 10 gauge)
The wiring for the hot tub originates at the main panel in our house from a 50amp double pole breaker. There's some heavy gauge wire that goes from the panel to another panel outside next to the spa where there is a 20amp double breaker (not gfci).
A) I believe this need to be changed to a GFCI
B) What amperage should that breaker be next to the tub?
shouldn't that be a 40 or 50amp?
mikec205 is offline   Reply With Quote
Old 08-08-2011, 07:55 PM   #2
Rewards Points: 77
The size of the breakers at the sub panel will depend upon the hot tub you have. For example, my Hot Spring brand, has a 50 amp main, then a 20 and 30 amp GFCI in the sub, wired w/ #8 and #10 ground. The manual or pre-delivery instructions for your model should specify the electrical requirements.
daveplot is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
