Hot Tub Will Not Start - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2012, 10:20 AM   #1
Hot tub will not start
Hot tub will not turn on after refilling. It sat empty for a week.
Tanner121212 is offline   Reply With Quote
Old 12-09-2012, 10:26 AM   #2
Rewards Points: 160
Okay. What steps have you taken so far to find out whats wrong?
Old 12-09-2012, 10:43 AM   #3
Question
I emtied and refilled it and made sure there was no air caught in the system. When you switch the breaker on you here 1 little click in the tub controls.
Old 12-09-2012, 10:48 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
What we know so far:
- The tub was emptied and refilled, making sure there is no air trapped.
- The tub "clicks" when the breaker is turned on
What we don't know:
- Brand of tub
- Model of tub
- Age of tub
- 120 or 120/240V
- GFI breaker?
- If you have a tester
- Your level of electrical expertise
- Your location
- If you have the number of a technician who can troubleshoot this tub
Old 12-09-2012, 11:04 AM   #5
- Age of tub My guess is ten years
- 120 or 120/240V 240V
- GFI breaker? Yes
- If you have a tester Yes
- Your level of electrical expertise OK but no expert
Old 12-09-2012, 11:24 AM   #6
Is the GFI breaker holding, or tripping?
Have you tested for power at the terminals in the tub control panel?
IMO if there is power to the terminals inside the control panel the next step is calling in a technician. Unless you have the knowledge and tools to troubleshoot things like this it's just not worth messing with.
Old 12-09-2012, 11:53 AM   #7
Who drained the tub? You or someone else?
Why was it drained?
If you did not drain the tub, could the other person have unplugged something? Or turned off something behind that hidden compartment where the pump and so forth is? Tripped the GFCI? (Press "Reset")
Also try turning the breaker(s) fully off, then back on. There could be a breaker at the hot tub as well as another at an electric panel at the house.
Billy_Bob is offline   Reply With Quote
new pergo - where to start laying first course snowninja Flooring 4 09-25-2010 04:47 PM
compressor wants to start but won't wetbar HVAC 13 06-17-2010 06:15 PM
Homelite weedeater won't start. Out of ideas. Jasnall Landscaping & Lawn Care 7 06-03-2010 01:12 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 08:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 10:58 AM
