Hot Tub Ground From Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 08:50 AM   #1
Question
Hot tub ground from panel
Hi, Just installed a new hot tub. ran #6 NMB inside to # 6 THHN/THWN outside with a #10 ground. My inspector wants a #8 ground per a grey comment in the hot tub manual. I can pull out the #10 and add a #8 outside but what do I do inside since I ran NMB? Any help would be appreciated.
HutchNJ is offline   Reply With Quote
Old 04-19-2013, 01:54 PM   #2
Licensed electrician
Rewards Points: 1,300
What was the reason given for the red sticker? The inspector should be able to provide the reason something failed.
If the manufacturer states what is needed for the wiring that is what you need to do, even if it exceeds the electrical code.
Old 04-19-2013, 02:05 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,908
If your inside wiring is #6 NM, then the ground is already large enough. Right?
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 04-19-2013, 02:28 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I think 6-3 NM only has a #10 ground
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
mpoulton (04-19-2013)
Old 04-19-2013, 04:35 PM   #5
Some tubs are calling for a full sized #6 grounding conductor.
Old 04-19-2013, 05:03 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I've yet to wire a tub that hasn't required a full size EGC, makes it impossible to use NM.
Old 04-19-2013, 05:09 PM   #7
I would like to know what the tub makers think they are accomplishing by specing a full sized ground. A waste of materials for no benefit.
Old 04-19-2013, 05:11 PM   #8
E2 Electrician
I'm not sure, but I'm betting someone uneducated in the electrical field thought this would resolve any type of warranty issue claimed by the owner.
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
New detached garage with sub and ground, house has no ground at panel italie Electrical 9 09-12-2011 03:43 PM
Service panel ground downunder Electrical 13 05-13-2011 05:46 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
