We talked about the Disconnect for my hot tub here the other day. I went to get one. There were a number of the AC disconnects - cheap about $7, but they were not setup for top access because they were outdoor boxes, so no top KO.
I need to be able to run in a KO in the bottom and out a KO in the top. So I got a small BR panel. The GF is going in my main CH panel. So this is just for the in room disconnect.
The BR panel was empty and I got a 50AMP BR breaker for it. The box looks like this:
The breaker switch is exposed in this panel, the cover does not cover up the breaker switch.
Will this be ok to use as my hot tub disconnect?
Only concern I had is that it has no ground bar, so I was going to get clamp and grounding screw to bond the ground to the box.
I just want to make sure this box is ok before I put it in place.
Jamie
