Hot Tub Conduit & Grounding - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2008, 02:47 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
HI;
I bought some of the grey schd 40 1" electrical PVC ENT tubing for my run to my indoor - in house hot tub. I realized after looking at the routing, that it would be easier to use 3/4" EMT due to being able to bend it in ways I can't with ENT.
I have not been able to figure out if for an indoor spa if I can use EMT as the ground path or if I need to still run a ground wire. 680.43(E) appears to apply. Section (E) 1 I suspect applies to RMC or IMC that is threaded and I suspect it would not apply to EMT. Section (E) 2 says "Metal-to-metal mounting on a common frame or base". I don't know if that applies to EMT or not.
Do you think it is a good idea to run EMT to the hot tub (I know it is allowed per 680.25 (A), I am just looking for an opinion). If I do run EMT, do I need to run a seperate grounding conductor or can the EMT serve as a ground? If the EMT can serve as a ground, then I would run 3 #6 wires to the tub through the EMT. If it can't then I would add an addition wire for the ground path (#8 gage for the ground path).
If I understand the code correctly, in 680.41, I do not need to provide a disconnect at the Hot Tub. I have a 50A GFCI breaker that will fit in my Cuttler Hammer Panel, and I was thinking of running a connection from the tub directly to the cuttler hammer panel. Have I understood the code properly, and is that a proper residential setup?
Thanks.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-15-2008, 03:01 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Even if it were allowed to use the EMT you should run a dedicated ground for a spa.
You do not need an emergency shut, off but you DO need some form of disconnect. This can be the breaker if it is within sight.
Speedy Petey is online now   Reply With Quote
Old 11-15-2008, 03:17 PM   #3
The ground is supposed to be insulated&dedicated. Use a disconnect and box rated for your use.
rgsgww is offline   Reply With Quote
Old 11-15-2008, 04:16 PM   #4
DIY'er
jamiedolan's Avatar
680.41 - " Emergency Switch for Spas and Hot Tubs" ... ... "This requirement shall not apply to single-family dwellings."
Is the disconnect switch something different than an emergency switch? If so, what kind of disconnect are we talking about using, just a cheap throw lever disconnect box?
Jamie
Old 11-15-2008, 04:21 PM   #5
DIY'er
jamiedolan's Avatar
Thanks. I will run a ground - no problem. On basically anything other than a hot tub, I would be able to use the EMT right?
I am confused about the disconnect requirment, I read the code to say that residential homes do not need the disconnect / emergency switch, 680.41. Did I misunderstand this?
Jamie
Old 11-15-2008, 04:41 PM   #6
Electrician
Jamie
680.41 is for an emergency switch, which is not required for single-family dwellings,
680.12 is for maintence disconnecting means, which IS required.
chris75 is offline   Reply With Quote
Old 11-15-2008, 04:57 PM   #7
DIY'er
jamiedolan's Avatar
Would this be an acceptable disconnect?
http://www.lowes.com/lowes/lkn?actio...RNM&lpage=none
Jamie
Old 11-15-2008, 06:13 PM   #8
Electrician
Jamie
Why not get something cheaper like a AC disconnect? Unless of course you want/need the gfci protection at that location.
Old 11-15-2008, 06:21 PM   #9
DIY'er
jamiedolan's Avatar
I have a couple disconnects lying in the garage, but they are both fused. I guess it would not hurt anything to have a couple fuses in the disconnect as long as they are sized =to or larger than the 50A GF that protects it in the main panel.
My disconnects are pretty ugly thought for a finished room. I wonder if there are any nicer looking disconnects available.
Jamie
Old 11-15-2008, 06:59 PM   #10
Electrician
Jamie
Everything electrical is ugly, unless of course your an electrician.
Old 11-15-2008, 07:03 PM   #11
Rewards Points: 2,350
Jamie
I am no expert on hot tubs, so I'll leave that to the others. But the question above, as to whether EMT is a suitable grounding path, the answer is yes. However, a good practice is to always pull a separate ground. Always make sure your fittings are tight, and pull a ground wire.
Old 11-15-2008, 09:09 PM   #12
Hot tubs DO require a dedicated insulated grounding conductor. There is an exception though that lets us use and Chapter 3 wiring method for the interior portions of the wiring.
See NEC 680.43
Old 11-15-2008, 11:36 PM   #13
DIY'er
jamiedolan's Avatar
See NEC 680.43
If I read this correctly, Chapter 3 tells us in 358.60 that EMT can be used as a grounding conductor, and 680.43 tells us that for indoor installs that we can follow chapter 3. So that means that technically for a indoor installation that uses all EMT, it does not require a seperate grounding wire? But I get the idea it is a good backup to have?
Jamie
Old 11-16-2008, 07:11 AM   #14
No it doesn't, and YES it is!
Grounding light box n0c7 Electrical 10 10-06-2008 03:20 PM
grounding, making me crazy sparky2474 Electrical 3 09-17-2008 10:40 AM
Grounding conduit instead of using a ground wire? stringtheories Electrical 10 08-02-2008 12:42 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
