Hot Tub Breaker Tripping - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 06:04 PM   #61
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by Stubbie View Post
I hope this puts to rest the neutral issue..... the triton is the only platinum series spa that requires only a 3 wire 240 volt supply 2 hots and a ground. the others require a 4 wire because they have 120 volt loads and 240 volt loads.
To say again the gfci is wired incorrectly and the terminal block is a 3 wire connection!! That neutral is not required and on top of that it is connected to the ground.....!!!
Sorry for all the confusion on that. I do see what you mean with the terminal block being only a 3 wire setup, and also saw where the ground was incorrectly connected. When I read the manual and they said it required a 4 wire setup, I wondered if the terminal block was really correct or if it was messed with and something else was jumpered in that pile of wire where I could not see it.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-22-2009, 06:09 PM   #62
Ah, OK - Thanks
I did see the 1st section
Then I saw the 2nd one & thought that over-rode the 1st one as the 2nd was specific to hot tubs
Old 02-22-2009, 06:10 PM   #63
DIY'er
jamiedolan's Avatar
Originally Posted by chris75 View Post
Jamie, look at the wire termination block, its only a 3 wire hookup. 2 hots and a ground.
Thanks, I did see that, I just didn't know if the wiring on the hot tub side of the block had been messed with.
Would that terminal block otherwise look the same for a 4 wire setup, other than it would have 4 wires on the right side H,H,N,G? (vs now H,H,G)
Jamie
Old 02-22-2009, 06:14 PM   #64
Electrician
Jamie
Yes, and that white label in the background would change as well..
chris75 is offline   Reply With Quote
Old 02-22-2009, 06:19 PM   #65
DIY'er
jamiedolan's Avatar
Thanks, Now I realize what the tag must say, Ground, Line, Line, blank on the bottom space. Got it.
Jamie
Pool Main breaker keeps tripping beckyreyes Electrical 12 08-11-2013 04:06 PM
Main Breaker is tripping rdmccaw Electrical 18 02-05-2009 10:27 PM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
Tripping Wrong Breaker woodworksnmore@comcast.ne Electrical 15 03-28-2008 01:47 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
