Old 10-28-2012, 04:57 PM   #1
Question
Hot Tub 240volt wiring
I will be installing a new jaccuzzi tub which requires a 240 volt 50 amp breaker. My wire run will be 150 feet. What size wire should I use?
MarkMaurer is offline   Reply With Quote
Old 10-28-2012, 05:13 PM   #2
E2 Electrician
stickboy1375's Avatar
There is more involved to wiring a hot tub then just the correct wire size.
Old 10-28-2012, 06:56 PM   #3
Nice House. The trim details make it really work. I am trying to get one question at a time answered. I wired for low voltage in my backyard a year ago and had to run a larger size wire about half of the distance because the run was too long. For my spa I have a long run again. I hoped there was a standard where, say, #6 wire was suitable for at least the 150' I have to run.
Tags
240 volt 50 amp, spa wiring, wire length required
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 10:43 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
