Hot Tub 240volt Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2012, 04:50 PM   #1
Hot Tub 240volt wiring
I am installing a new jaccuzzi spa that requires a 240 volt 50 amp breaker. My question is about the wiring. My total run is 150 feet. what size wire do I use?
MarkMaurer is offline   Reply With Quote
Old 10-28-2012, 07:00 PM   #2
joed's Avatar
Rewards Points: 11,582
I think #6 would be fine. What is the actual load of the spa unit including any heaters?
The Following User Says Thank You to joed For This Useful Post:
MarkMaurer (10-28-2012)
Old 10-28-2012, 07:50 PM   #3
Don't know until the spa is delivered. MFR. recommended the 50 amp breaker though. I've run 1 inch conduit, should be good. Just wondered if maybe I needed to run #4 half way to a junction box and then the rest #6.
Old 10-28-2012, 09:37 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
As Stickboy stated in the other thread you started on this topic...there are many codes that affect hot tub wiring.
Convenience Receptacle
GFI Protection
Disconnect
Equipotential grid
Just to name a few
Old 10-28-2012, 11:24 PM   #5
joed's Avatar
#6 is good for 60 amps. Since they recommend a 50 amp breaker the spa probably uses less than 40. That should be fine on #6 for the distance you specified.
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 10:43 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
