Hot Tub - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2012, 12:06 AM   #1
Exclamation
hot tub
I am looking to hook up a hot tub sitting on my property safely. It is a 220v and I was wdering if you can hook it up to a 120 system in any way? If not how do I get power to it?
rockerwannabe is offline   Reply With Quote
Old 07-31-2012, 12:50 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Only way to hook it up safely would be with an experienced electrician. It is true this is a diy site but your questions and lack of detail about the tubs specifications and your experience lends me to defer you to a professional.
Old 07-31-2012, 05:27 AM   #3
Lol, granted I did not give much info on the tub but that is because I know nothing about it. It is a hunk that has been sitting on my property for years and I just now fixed it up. I am not a novice to electrical work, I have dealt with 120v my whole life the only issue, I have is that I have dealt with 220v and I had a basic question that I layed out sorry I was not more specific. The only things I can tell you really is that it is 220v and there is only three leads which is what made me think it was odd because I have a friend that told me there should be four....
Old 07-31-2012, 06:58 AM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
whats the voltage on the nameplate say? How can anyone say anything without looking at that first?
Old 07-31-2012, 07:02 AM   #5
Rewards Points: 1,294
If this is a 220 volt hot tub, You will need to run a 220/240 volt line out to the site. This will need to be GFCI protected with proper disconnect switches etc. You will also need to set up a correct bonding system around the hot tub. I would suggest you start with NEC 680.4 and read from there what the requirements are for installing a hot tub.
As for the original question, no, you can not hook this up to 120 unless the equipment is rated for it. Please provide us with more info on the pump motor, heater and electrical requirements of this unit.
danpik is offline   Reply With Quote
Old 07-31-2012, 11:54 AM   #6
Rewards Points: 82
Anyone that has dealt with 120 his whole life, knows more about 240 than 120.
Old 07-31-2012, 12:31 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Just reading this suggests it would be WELL within your best interest to hire an electrician to do this job.
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (07-31-2012)
