Hot Screw On Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 03:03 AM   #1
Hot Screw on Dimmer Switch
Hey all!
I have a 1000 watt dimmer switch ganged in a box with a 600 watt dimmer switch. The chart I have says to derate the 1000 watt dimmer to 800. It's controlling 10 65-watt floodlight bulbs, and one of its wall plate screws is hot. Not hot enough to burn but hot enough to be uncomfortable to touch for more than a few seconds. The other 3 screws are warm-ish but fine. Is this normal?
Thanks!
thriftymegs is offline   Reply With Quote
Old 06-26-2012, 07:56 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Yes..
Old 06-26-2012, 03:10 PM   #3
Rewards Points: 83
No, that is not normal.
rubberhead is offline   Reply With Quote
Old 06-26-2012, 05:40 PM   #4
Can you offer any advice?
Old 06-26-2012, 08:41 PM   #5
Old 06-26-2012, 11:20 PM   #6
Registered User
Rewards Points: 5,516
Please, only this one thread on exact same question, someone will be along soon, thank you, Gary.
Gary in WA is online now   Reply With Quote
Old 06-26-2012, 11:27 PM   #7
" Euro " electrician
frenchelectrican's Avatar
There is one surefire tip which I done this all the time is get the metal switch plate cover and that metal switch plate will act like heat sink.
The question is how hot it is??
Some of the dimmers can run warmer than other brand names will do.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
bbo (06-27-2012)
Old 06-27-2012, 04:57 AM   #8
dmxtothemax's Avatar
Rewards Points: 5,354
If you can improve the air flow behind the dimmer,
The heat build up will improve !
But yes it is normal for dimmers to get quite warm.
The components are usually rated for 85 degree's celcius.
So warm to you is cool for the components.
Also using a metal fascia plate will help dissipate some
of that heat.
dmxtothemax is offline   Reply With Quote
Old 06-27-2012, 05:27 PM   #9
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Yes it is...
During normal operation, dimmers do get warm to the touch. Wallbox dimmer efficiency is typically around 99%. The other 1% is dissipated in the dimmer as heat. So a dimmer on a 600W load would produce around 6 watts of heat. This is on the order of a small nightlight. Operating on itís rated load, Lutron dimmers will stay below the UL limits of 140oF (60oC).
Old 06-28-2012, 05:27 PM   #10
If you derated it like the manufacturer suggested, it will operate within normal specs. Having a hot switch is perfectly fine when it comes to dimmers as they dissipate the extra energy as heat. A hot dimmer is not anything to be alarmed over.
triden is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
wiring a digital dimmer switch albertlayden Electrical 8 01-27-2012 06:33 PM
replacing an existing 1-way decora light switch with a dimmer switch maljeff Electrical 3 01-11-2012 11:49 AM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
Dual Dimmer Switch Headache! BrumGuy Electrical 3 12-02-2008 02:39 PM
