Hot Neutral Reverse - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-12-2012, 09:01 AM   #16
Sorry it took so long for me to respond. I've been really busy on the house and haven't been on te forum in a while. I did get a better tester and as many Of you pointed out all the outlets tested correct. It amazes me because even the home inspector said some where reversed. But I guess you really can't trust those inexpensive testers. Thanks for all the great info!
NateW is offline   Reply With Quote
Old 06-13-2012, 05:46 AM   #17
Rewards Points: 1,300
Glad everything worked out for you.
danpik is offline   Reply With Quote
Old 06-13-2012, 12:07 PM   #18
"False negatives".
A false positive would be where a bad outlet tested good and that is less desirable in this case than a false negative.
Bad ground / reverse neutral maurice.lecoupe Electrical 6 03-01-2011 06:11 PM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 02:10 PM
HOT / NEUTRAL REVERSE.... need help to fix DIYneedsHelp Electrical 10 10-05-2009 06:36 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Ground / neutral reverse. Important or not? Deck Electrical 8 07-09-2008 07:59 PM
