Old 12-06-2010, 12:03 PM   #1
Hot & neutral outlet terminals
Replacing some outlets that are not pigyy backing from one to the other. They are utilizing the top and bottom screws in a series. My question is does it make a difference if the hot and neutral wires are on the receptacle (i.e incoming hot wire attached to bottom hot screw and neutral attached to bottom neutral screw). Or is ok if the incoming hot is on the bottom and incoming neutral is on the top? These are receptacles in the middle of the series and not at the end. Thanks
suboveryde is offline   Reply With Quote
Old 12-06-2010, 12:16 PM   #2
Electrical Contractor
Does not matter as long as the receptacle is not switched, and you can only have one wire under each screw.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Poor neutral connection in outlets Albondigas Electrical 5 10-04-2009 12:32 AM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-15-2009 12:17 AM
Sub panel grounding sluggermike Electrical 27 11-11-2007 02:23 AM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
