Hi all,
Thanks in advance for any reply as any help would be greatly appreciated.
I have ran some additional wiring and boxes to include two GFCIs, and three single light vanity fixtures in a bathroom renovation I am currently working On. It is a complete down to the studs redo. The bathroom feed for the existing fixtures is in circuit (I think) with the rest of the lights and outlets on my upper floor. I currently have added the outlets and lights with the ability to connect them to separate circuits as soon as I can change the main box. But for now I have them in circuit from the same feed that feed the existing lights and outlets(that are now gone).
My problem is basically this, I am getting 69-70 VAC at my light feeds when the switch that controls them is off. That is checking neutral to hot as the wires I have added have a ground but the house wiring does not. I have checked continuity on the switch and it is functioning fine. The wires runs from an existing box to the first GFCI. It then branches to the second GFCI and up to the first vanity light. At this point the hot leg runs to the switch for the lights and the power splits to a red lead to give constant power to the existing light which is in the ceiling. From the 1st light box I ran a red (to existing light), Black hot (from Switch for vanity lights), white (neutral for all) and a ground to the next box (second vanity light). From this box the red feeds the existing light, the black pigtails to second vanity light and out to the third vanity fixture and the white gets connected to all neutrals. The third vanity fixture is a black, white and ground. I think I have this all right. I have checked and rechecked all my connections and they are good, my outlets both get 123 VAC and the lights get the same when they are on, but when they are off they get 69-70 VAC. what did I do. Is it possible that I have a Neutral shorted with a Hot.
Also I dont know if this is normal or not but when checking continuity are you supposed to get a morse code like beep from the hot and neutral on outlets. Any help in either is greatly appreciated.
