Hot/ground Reversed - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-19-2012, 07:17 AM   #16
Electrical Contractor
kbsparky's Avatar
Well, it WAS a failed back-stabbed connection that caused all the problems here in the first place .... just sayin' ...
-KB
Old 08-19-2012, 07:27 AM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
And this one wasnt back stabbed... just sayin'
Old 08-19-2012, 08:08 AM   #18
Rewards Points: 506
Soooo....failed backstabs are not the only points of failure. Is that the lesson?
jlmran is offline   Reply With Quote
Old 08-19-2012, 08:18 AM   #19
E2 Electrician
Well, considering less then 1% of electricians use a torque screwdriver when installing receptacles, i doubt that connection is any better then backstabbing, for what ever reason, backstabbing just takes the brunt of the failure rate.
In my years in the trade, i've come across just as many incorrectly installed devices with screws as with back stabbed devices, maybe even more actually...
Old 08-19-2012, 08:21 AM   #20
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I completely disagree. I'm not implying that taking your impact to tighten the screws is a good idea, but every backstabbed device I take out looses at least 1 wire when I pull it out of the wall...and its usually the neutral for some reason.
Old 08-19-2012, 08:47 AM   #21
E2 Electrician
I believe you are over exaggerating your statement, I always have to cut them or insert a skinny screw driver to release the wire.
Light Switch Reversed.. Up is Off.. down is on caseynshan Electrical 11 07-12-2014 06:10 PM
Can't Find Reversed Polarity On A Circuit SirMissedALot Electrical 16 09-08-2011 05:50 PM
GFCI tester shows hot/ground reversed, then not reversed bw777 Electrical 7 02-04-2011 09:16 AM
hot / neu wiring reversed, getting a shock PIGEONS Electrical 2 11-07-2010 05:43 PM
pos/neu reversed help please mtstreicher Electrical 11 12-10-2009 01:17 PM
