Hot Doorbell Button - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 05:41 PM   #1
hot doorbell button
I just ran my doorbells. the one that showed 95 degrees on my sperry infrared thermometer is a flush mount with a halo light around it. It was a 13 dollar one from lowes. It is run from a 16v 10va transformer with 24 gauge wire. I checked the transformer and it is not hot, so im guessing it is the light itself.
Anything i should be concerned about?
rustic is offline   Reply With Quote
Old 01-26-2009, 06:23 PM   #2
Is it the door button or the bell thats hot?
Old 01-26-2009, 06:52 PM   #3
its the door button
Old 01-26-2009, 06:54 PM   #4
DIYer
It's probably fine. Do you know if the pilot light is incandescent?
Gigs is offline   Reply With Quote
Old 01-26-2009, 07:01 PM   #5
the package doesnt say.
Old 01-26-2009, 10:24 PM   #6
As long as its the button thats showing heat and not the bell thats hot, its not a problem!
Old 01-27-2009, 06:36 AM   #7
good deal, thanks
Old 01-27-2009, 07:52 AM   #8
the Musigician
DangerMouse's Avatar
that's their special anti-solicitor doorbell, but i think yours is faulty, ours is 250 degrees. -=chuckle=-
DM
Old 01-27-2009, 11:29 AM   #9
At 95℉ it should feel neither cold nor warm to your skin.
Old 01-27-2009, 11:43 AM   #10
DIYer
95 feels a little warm. Your skin isn't at 98.6.
Old 01-27-2009, 12:16 PM   #11
". . .can take 33 to 35 degrees as the skin temperature range, based on calorimetric data dating from the World War II era."
I stand corrected. Stand by while I recalibrate my digital probe [clicking sound].
What was your ambient temp. when you measured the button temp.? Did you correct your meter for the low emissivity of the button?
With 10VA and all the power lighting the bulb and an ambient of 35℉ this gives a thermal resistance of 6℉ per watt.
At 16v, it can't be neon. If the light reacts instantly it might be an LED.
I really need to get a day job.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Wiring a Doorbell jelly Electrical 3 05-30-2008 11:48 AM
Replacing Button for Electrical Garage Door Opener FL_Deb Electrical 6 04-22-2008 11:36 AM
how to replace, or maybe swap, this odd doorbell setup joeyboy General DIY Discussions 7 12-16-2007 12:53 PM
Tried replacing doorbell....now it doesn't work. ConstantChange Electrical 9 11-18-2007 10:12 PM
