Hot Dimmer Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 07:31 AM   #16
Licensed electrician
Rewards Points: 1,630
Most 600 and 1000 watt dimmers do not come with the cover plate. Larger sizes do include a finned cover, but are typically used in commercial settings.
Old 01-04-2012, 07:31 AM   #17
Ironlight's Avatar
You're fine. Dimmers work by simply increasing the resistance in the circuit and the result is heat. What you're experiencing is normal. If the load on the switch is within its spec'ed capacity and the box that it is installed in is to code then you have nothing to worry about from a safety perspective, which you said is your only concern.
By the way, with 18 bulbs, that must be one impressive chandelier
Ironlight is offline   Reply With Quote
Old 01-04-2012, 09:59 AM   #18
Originally Posted by jproffer View Post
Maybe
Didn't realize I was "not nice" but ok.
Bottom line of it was, either stop touching it.....or get diff. screws.....right?
The reason doesn't really matter. Dimmers get hot....fact of life.
HOWEVER........
OP:
Sorry for being "not nice".
"JPROFFER" - Don't worry about it...I got what you were saying and it didn't bother me a bit.
blue sky is offline   Reply With Quote
The Following User Says Thank You to blue sky For This Useful Post:
jproffer (01-04-2012)
Old 01-04-2012, 10:15 AM   #19
The box is original from the builder and the switch is within capacity. Sounds like I'm all set with this. Thanks again for everyone's help.
Dimmer switch issues idlewatcher Electrical 0 03-07-2011 01:28 PM
Changing from dimmer to regular switch..help!!!!!!!!!!!!!!!!!!!!!!! Gomezy3k Electrical 8 10-04-2010 03:26 PM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 12:25 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 10:57 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
