Hot Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 10:01 PM   #1
Hot dimmer switch
I have a 1000w dimmer switch that's connected to a chandelier and it gets hot after a short time. The chandelier has 18, 40w bulbs (720w) and it's on a 20amp circuit. My first question is whether or not I should be concerned about the hot dimmer (if you touch the plate screw heads, they're hot enough to be uncomfortable, but not hot enough to burn skin). My second question is why would a 1000w switch get hot under this load (defective switch or is it normal?)
Thanks.
blue sky is offline   Reply With Quote
Old 01-02-2012, 10:07 PM   #2
jproffer's Avatar
Rewards Points: 712
Dimmers get hot.....**shrug** that's the way it is.
Get some nylon screws...... or quit touching it
jproffer is online now   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
blue sky (01-03-2012)
Old 01-02-2012, 10:34 PM   #3
Msradell's Avatar
Rewards Points: 210
+1
Msradell is offline   Reply With Quote
Old 01-02-2012, 10:35 PM   #4
Mad Scientist
At that sort of load, you might try using a metal cover plate instead of plastic, if you can stand the look. It'll get warm, but hopefully not hot. It gives the dimmer more area to spread out & dissipate the heat. It'll prolong the life of the dimmer.
Otherwise, as jproffer said, get some nylon screws.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
Old 01-03-2012, 01:55 AM   #5
" Euro " electrician
frenchelectrican's Avatar
For me I will grab a metal switch plate cover that will act like heat sink that will help to keep the dimmer cooler.
Is this dimmer in single gang box or in mulit gang box ( if latter you will have to restrict the wattage rating )
Merci,
Marc
Old 01-03-2012, 06:24 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,822
THAT is a lot of bulbs....and a lot of light.
Does it only get hot when you have it dimmed? If so, that is normal. What kind of dimmer is it?
If you find that your keeping it dimmed all the time, you might consider going to a smaller bulb, say 25w....with that many lights, 25w would still give you a lot of light and not have to be dimmed as much.
Old 01-03-2012, 10:15 AM   #7
Merci,
Marc
It is a single gang. By how much will I need to restrict the wattage?
Old 01-03-2012, 10:21 AM   #8
It's a Levitron dimmer and it get's hot when dimmed and full power. The lights are in tinted (fake candle looking) cylinders, so they don't put out as much light as it sounds and the lights came with the chandelier.
My main concern is safety and if the hot dimmer is fine as is or not.
Old 01-03-2012, 11:00 AM   #9
The hot dimmer is normal unfortunately... If you don't like it switch you an on/off switch instead of the dimmer.
jfrotten is offline   Reply With Quote
Old 01-03-2012, 01:29 PM   #10
Licensed electrician
Rewards Points: 1,622
Dimmers only need to be derated when ganged next to other dimmers in the same box.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
COLDIRON (01-04-2012), frenchelectrican (01-04-2012)
Old 01-03-2012, 05:53 PM   #11
Thanks for everyones help!
Old 01-03-2012, 10:18 PM   #12
Missouri Bound's Avatar
And if you find that you always set it at the same level, just change out the bulbs to give you that level and replace it with a simple on/off switch.
Old 01-04-2012, 05:39 AM   #13
Rewards Points: 1,216
If you here to help maybe you could be a little nicer instead of being short and you could have asked a couple key questions like derating , single gang or double, wattage, etc.
COLDIRON is offline   Reply With Quote
Old 01-04-2012, 06:58 AM   #14
jproffer's Avatar
Rewards Points: 712
Maybe
Didn't realize I was "not nice" but ok.
Bottom line of it was, either stop touching it.....or get diff. screws.....right?
The reason doesn't really matter. Dimmers get hot....fact of life.
HOWEVER........
OP:
Sorry for being "not nice".
Old 01-04-2012, 07:24 AM   #15
Rewards Points: 1,512
The dimmer may need a special finned cover plate and metal screws in order not to overheat. Usually the dimmer comes with the proper cover plate. It that got lost then you will need to reduce the load (wattage) of light controlled by the dimmer, reducing to 50% of dimmer rating is not unheard of.
The Following User Says Thank You to AllanJ For This Useful Post:
Dimmer switch issues idlewatcher Electrical 0 03-07-2011 01:28 PM
Changing from dimmer to regular switch..help!!!!!!!!!!!!!!!!!!!!!!! Gomezy3k Electrical 8 10-04-2010 03:26 PM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 12:25 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 10:57 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
