-   -   hot 3way dimmer (http://www.diychatroom.com/f18/hot-3way-dimmer-31678/)
moondog111 11-11-2008 05:10 PM
hot 3way dimmer
Hi again!
Why is the new Lutron dimmer I installed in a new 15 amp lighting circuit of 9 cans getting so hot (temperature), where the fixture is controlled by two switches (one is the dimmer) and the power goes through the light. By the way, there is a slight hum when dimmed and all 9 cans have 60 watt halogen spots in them.
I admit that I wired the switches incorrectly at first. I understand how the current runs for 3 way, but not which terminal is which on the switch.
Thanks!
Rob
TazinCR 11-11-2008 05:34 PM
Thats 540 watts is it rated for that?
moondog111 11-11-2008 06:55 PM
Thanks Tazin.
It says on the dimmer 600 watts max... and then it says 500 one side removed, 400 two sides removed.... what does that mean?
Appreciate it.
Rob
220/221 11-11-2008 07:02 PM
Dimmers get hot. It's part of the deal. Yours is loaded.
When you put more than one dimmer in a box, next to each other, you have to remove a small strip of the metal. This reduces the ability of the dimmer to disapate heat so the rating is lower.
moondog111 11-11-2008 07:31 PM
Thanks! Makes perfect sense! I see on-line for somewhere North of $30 I can get a 1000 watt dimmer...I think I better do that.:furious:
sweaty 11-11-2008 07:34 PM
Get dimmable CFL's. You'll save a lot of money in the long run and not overload your dimmer.
220/221 11-11-2008 08:17 PM
Every "dimmable" CFL I've seen sucked. The don't dim down enough.
sweaty 11-12-2008 06:04 AM
In my house, I have dimmers in most rooms (from the previous owner) and I only use them in the bedrooms to check on the kids at night. So I use CFL's in the other rooms where we spend more time and don't dim the lights much.
