Horton Modular Homes - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 09:48 AM   #1
How do I change out the light switch? The switch is a box that has 4 cables leading to both upper and lower connections. It looks like cable
DTfromGA is offline   Reply With Quote
Old 11-10-2010, 10:11 AM   #2
Rewards Points: 246
It's a trailer right? I have never worked on trailers so I am not exactly sure as to what you have. But I think I understand. Can the wires be removed without cutting them? If so, mark where each wire goes or make a little drawing. Then look for a place that sells trailer equipment or contact the manufacturer for a replacement.
J. V. is online now   Reply With Quote
Old 11-10-2010, 10:45 AM   #3
I already looked at them and the wires cannot be disconnected without cutting them. I will probably have to by a new switch and box from the manufacturer, I just didn't want to have to pay to have them install it. As you know, in a 15 year old place, they will probably all start wearing out.
But, thanks anyway
Old 11-10-2010, 10:48 AM   #4
Mad Scientist
I think I know what you're dealing with there. Those factory switches and outlets are a pain. How much slack is in the cables? If there's enough slack that the cables can extend about 6-8" out of the wall, the job gets much easier.
A picture would help a lot here, 4 cables seems like a lot to be entering a single light switch of the type I'm thinking of.
McSteve is offline   Reply With Quote
Old 11-10-2010, 11:30 AM   #5
Retired Electrician
I ran into this in two different places (1) a trailer (moble home) and a (2) manufactured home. What I did was pull the old switch out and identified the cables.....then got a plastic cut-in box, switch, etc. and put it all together. Worked great.
Lsparky is offline   Reply With Quote
The Following User Says Thank You to Lsparky For This Useful Post:
J. V. (11-11-2010)
Old 11-10-2010, 11:38 AM   #6
Mad Scientist
Yep, that's the way I've always done it. Usually there's plenty of slack. When there isn't, then it gets tricky.
Costs estimate help please for a newbie Basement vs crawl space Cancer Researcher Building & Construction 21 03-30-2012 06:59 AM
Palm Harbor Modular Homes vapros Off Topic 10 04-20-2011 11:54 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
Another Load Bearing Question - Modular Homes ch3howard Carpentry 2 08-17-2008 09:21 PM
Modular Homes? DaManAgain General DIY Discussions 10 01-13-2008 09:17 PM
