Hi Everyone,
I'm just about finished with my electrical upgrade.
The red in this picture is how the conduit is being run, it is all 2" galvanized rigid:
How should I connect the weatherhead?
Should I just ad it at the end of the horizontal run? Will that even work being against the wall?
I was thinking of using a LB (or an LL) and, using a nipple pointing up, have the weatherhead in the usual orientation.
Is an LB at the end near the weatherhead OK (per code)?
I would just use a regular 90 degree sweep, but it would put the weatherhead too far from the service hook up.
What you you guys do/suggest?
Thanks!
