Hoping To Move Bathroom Light In Ceiling Above Mirror - Electrical - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 08:28 PM   #1
Post
Hoping to move bathroom light in ceiling above mirror
I have an old light in the bathroom ceiling directly above the sink that I want to update. I want to put a new fixture above the mirror . I crawled in the attic and saw 3 sets of wires going to box where the old light is. the wires are not long enough to get to the desired location.The old light has a plate with 2 separate wires and chains coming out of it, connecting to 2 separate hooks with ugly globes on the ends as the fixtures. I removed the plate to see what I was dealing with, and saw the 3 sets of wires (attic) connected to the fixture. can I just disconnect the old fixture, add a length of the proper wire to reach the desired location, and connect the new fixture?
handyjc is offline   Reply With Quote
Old 08-23-2012, 08:58 PM   #2
DIY staff
Rewards Points: 7,174
If you want to patch the ceiling where the old light was --you will need to replace the box with a Junction box that is accessible from the attic.
Then,yes, you could add the new wiring for the sconce lights.
Old 08-23-2012, 09:08 PM   #3
Pure Genius
Rewards Points: 150
Is your current wiring grounded? If not you cant extend it to your new location.
Dierte is offline   Reply With Quote
Old 08-23-2012, 09:10 PM   #4
Yes it is grounded.
Old 08-23-2012, 09:12 PM   #5
DIY staff
A picture always helps---
Old 08-23-2012, 09:26 PM   #6
not possible at the moment sorry. I'm not sure if all three wires need lengthened? I ask because all three feeds are currently connected to the fixture. By connected I mean 5 black wires nutted together 5 white nutted together, and all the grounds connected.
Old 08-23-2012, 09:27 PM   #7
By grounded do you mean a third "bare" wire ?? If so than yes
Old 08-23-2012, 09:43 PM   #8
Pure Genius
Rewards Points: 150
Yuppers. Just jbox thoses wires in the attic and drop a new wire to where you want your light to go.
Old 08-24-2012, 06:55 AM   #9
Ok so I jboxed them and dropped the new wire, than connected the new fixture. Now when I turn on the power the light comes on when switch is off and tripps the breaker when I turn it on... I triple checked my connections and they are sound. What did I do wrong??? Help
Old 08-24-2012, 07:04 AM   #10
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
You splice all the blacks together and all the whites. It is a short circuit. One of the wires is a switch leg.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
handyjc (08-24-2012)
Old 08-24-2012, 09:03 AM   #11
Oh ok. that makes total sense.
bathroom vanity light height above mirror amakarevic Interior Decorating 6 03-22-2012 05:02 PM
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 09:32 AM
Light fixture in ceiling fan won't work. Tested DIYself Electrical 7 11-28-2010 12:52 PM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 04:06 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
