A (hopefully) Simpel Question About Pulling Through Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 09:14 AM   #1
Question
A (hopefully) simpel question about pulling through conduit
Hello
I'll be running electrical (24" deep, 1.5") and data (18" deep, 1.25")conduit (finally!!!!) to my garage in the next few days, and I was wondering...
What is the method for pulling cable THROUGH the conduit using a lead line (fishing line?) and making sure that there is still line left inside the conduit in order to pull future lines through? I may need to pull additional lines above any beyond what I initially bury, and I want to make sure that
a) there's room inside the conduit
b) there's something I can tie on to them to pull them through
Any replies are greatly appreciated.
spdorsey is offline   Reply With Quote
Old 01-12-2012, 09:18 AM   #2
Licensed electrician
Rewards Points: 1,490
You can just pull in another pull line when you pull the conductors.
Old 01-12-2012, 09:19 AM   #3
Rewards Points: 13,456
Use brick string not fishing line. Mono will stretch when pulling.
As your pulling for the first time make sure to also attach the string to the wires your pulling. That will leave you a string to pull wires back in the opposite direction.
Old 01-12-2012, 09:56 AM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by joecaption View Post
As your pulling for the first time...
make sure to also attach the string to the (other end of the) wires your pulling. That will leave you a string to pull wires back in the opposite direction.
And have some help.
Among other things... to feed and push the bundle of wire as you pull it.
Old 01-12-2012, 10:20 AM   #5
The pull string you want needs to be smooth. Masons string will cut into the insulation or pvc conduit on the bends.
Old 01-12-2012, 10:51 AM   #6
Thanks all for the replies.
Just wanted to make sure I was doing it correctly.
I was worried that having an additional pull line might not meet some mundane code requirement or something like that.
Old 01-12-2012, 11:57 AM   #7
Rewards Points: 128
Are you going to use a vacuum to suck the line through? How do you plan to get the initial string into the conduit?
Old 01-12-2012, 12:07 PM   #8
I'll thread it through as I install the conduit.
Old 01-12-2012, 12:19 PM   #9
MarginallyQualified
"it'll never work"
borrow a fish tape... to pull a clothesline rope through...
tie the clothesline rope to the wires.
(after the pipe and fittings are all set and supported)
Conduit Question md2lgyk Electrical 5 08-20-2011 06:45 AM
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 05:54 AM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Barn wireing and conduit question???? houstonbrama Electrical 8 07-09-2008 01:12 AM
pulling wire through old flexible conduit cbray Electrical 1 05-20-2005 03:55 PM
