Old 12-29-2008, 02:54 AM   #1
hooking up welder help?
i have a 50 amp input welder with 20% duty cycle that I put on a 60 amp breaker. Now that breaker is connected with 6/3 to a 30 amp dryer receptacle. The reason being is that the welder has a 30 amp male end which looks to have been switched from the 50 amp by a previous owner. The welder cord appears to be a 10/3 . My question is whether or not that 30 amp receptacle will be ok on the 60 amp breaker? From what I have read online the wire for the welder is small because the duty cycle allows a derating of .45 for it. Also I hear there is a 200% max overcurrent protection allowed for the breaker above the input amps. Will what I described work?
dmank is offline   Reply With Quote
Old 12-29-2008, 12:48 PM   #2
J. V.'s Avatar
The welder needs to be on it's own circuit. If it is rated at 50 amp, then you must use a 50 amp male plug and receptacle. Buy the correct cable with the attached plug.
You are right concerning the ability to use smaller conductors due to the duty cycle.
240v Welder powered by portable generator? MRJChannahon Electrical 19 03-30-2009 06:19 PM
240v Welder powered by portable generator jackgerd Electrical 10 11-06-2008 02:38 PM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 08:17 PM
MIG welding amakarevic Tools 28 02-20-2008 09:56 PM
Miller syncrowave 250dx Welder installation saddletramp Electrical 6 01-10-2008 02:11 AM
