Hooking Up Gas Fireplace - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2010, 08:51 PM   #1
Rewards Points: 152
hooking up gas fireplace
im trying to hook up a gas fireplace for my friend. I see the 14-2 bx cable coming out of the fire place. The things that bothers me is that their another cable coming out of the fireplace but with just one black cable inside it. Im not sure what that cable is for?
humberguy is offline   Reply With Quote
Old 03-21-2010, 08:53 PM   #2
Master Electrician
Rewards Points: 3,864
Millivolt switch for the burner? Where is the installation manual?
brric is offline   Reply With Quote
Old 03-21-2010, 09:20 PM   #3
Rewards Points: 152
my friend got the fireplace for free from his other friend, so im just guessing what the other wire is for.
Old 03-21-2010, 09:29 PM   #4
Master Electrician
Is it a 2 conductor thermostat type wire? Try to get some instructions from the manufactuer online.
Old 03-21-2010, 09:37 PM   #5
Rewards Points: 152
im going to my friends house tomorrow, ill try and get all the information i can. Ill respond by tomorrow.
Old 03-22-2010, 09:38 AM   #6
Rewards Points: 152
i think you're right that's it's a thermostat because theirs a red and black wire conductor. I looked at the the fireplace but couldn't find any kind of brand name of the fire place.
Now, how exactly do i hook up that thermostat and the 14-2 wire to the switch?
Old 03-22-2010, 09:45 AM   #7
Master Electrician
If it's anything like the ones I've done the 14-2 should go to a wall switch with a 120 volt feed. This switch likely controls a blower.
The other goes to a separate switch box with a switch only. After the pilot light is lit, this switch controls the burner on and off.
Without more details that is the best I can do.
Old 03-22-2010, 10:33 AM   #8
Rewards Points: 152
so to be clear, the 14-2 wire gets connected directly to an outlet(for power source) from around the area, then the thermostat is connected on a seperate switch?
Now, the thermostat has a red and black wire. Which wire is connected to the switch and which wire is connected to the neutral?
Old 03-22-2010, 10:51 AM   #9
Master Electrician
It is a millivolt switch. There is not neutral. One black and one red each to one screw on the switch.
I did not say the 14-2 gets tied into a recptacle unless the blower has a switch in the fireplace unit itself.
Old 03-22-2010, 10:54 AM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
Me, I know I would not hook anything up with gas and electricity without a maunual to go by, but thats the kinda guy I am.
especially at someone else's house!
Old 03-22-2010, 03:39 PM   #11
Originally Posted by humberguy View Post
iI looked at the the fireplace but couldn't find any kind of brand name of the fire place.
There should be a nameplate somewhere, either on the outside, or inside the unit where the electric and gas connections are. It might be covered in dust, so get a flashlight and see...
Willis
williswires is offline   Reply With Quote
Old 03-22-2010, 10:01 PM   #12
Rewards Points: 152
im gonna try really hard to see what's the manufacturer of that fireplace. Anyways, thanks alot for your help. Ill respond once i find the manufacturer.
Old 03-26-2010, 11:06 AM   #13
Rewards Points: 152
i found the information on the fireplace.
WARNOCK HERSEY
serial#WH-2253
natural gas
model#2DV3628N
I tried googling this information, but could not find any wiring diagrams for this fireplace
Old 03-26-2010, 11:43 AM   #14
Master Electrician
like jbfan says...never do a job without the manual . To many factors involved. The fan may be wired internally to come on with the thermostat which would mean you just tie it into unswitched power or it may need to have a seperate switch installed on it. If you wanted the fireplace to be a source of heat then you'd have to install a thermostat on the smaller wire and it would control when the fireplace comes on and turns off. Most likely from the sound of it though you just want this as more of a showpiece so the easiest thing to do is install two switches. One to turn on the blower and a seperate one to turn on the fireplace. And this takes us back to the manual for the type of switch that's recommended. Whatever you do...do not connect the small wire to 120V. The bx will get tied into 120v power. the small wire is most likely a 24v circuit with just a red and black that will get tied into it's own switch seperate from the house power.
andrew79 is offline   Reply With Quote
Old 03-26-2010, 11:52 AM   #15
Master Electrician
WARNOCK HERSEY
serial#WH-2253
natural gas
model#2DV3628N
Warnock Hersey appears to be testing lab not a manufacturer.
new opening in fireplace? burningbaal Remodeling 3 10-11-2009 01:18 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 08:17 AM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 08:10 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
