Hooking Up A Fluorescent Fixture To A Wall Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2009, 10:25 PM   #1
Smile
hooking up a fluorescent fixture to a wall outlet
hello all,
i'm new here. so forgive my terminology or lack there of.
i bought a 4' t12 fluorescent fixture and i want to safely plug it into a regular wall socket much like any other lamp. most how-to's are directed toward me installing it onto the ceiling.
would it be as simple as buying a 3 prong plug and connect the same color wires into each other with cap? also are there any dangers of doing this?
thank ya folks for your time
t1
tool1.0 is offline   Reply With Quote
Old 10-19-2009, 06:57 AM   #2
There is nothing unusual about a line cord from this sort of fixture. Some Fl. fixtures can be purchased with a simple factory installed line cord. Just be attentive in doing same and make sure there's a strain relief on the cord. By the way, where else but from the ceiling would you mount it?
oilseal is offline   Reply With Quote
Old 10-19-2009, 08:09 AM   #3
Rewards Points: 1,512
No problem.
Be sure the power cord doesn't catch on sharp metal edges. You can use a clamp that screws into the 3/4 inch or so round hole that most fluorescent shop light fixtures have for stringing wires through, and this protects the cord.
Fluorescent lamp requires wall switch to be cycled several times before lighting. joejean Electrical 5 09-04-2008 08:48 AM
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
Adding an outlet to a wall switch Keyo77 Electrical 6 01-01-2008 11:22 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
ceiling fixture with on-off wall switch carlu Electrical 1 03-04-2005 08:13 AM
