-   -   Hooking up a fire alarm (http://www.diychatroom.com/f18/hooking-up-fire-alarm-163325/)
jhr7 11-14-2012 01:18 PM
I recently pulled a fire alarm out of the wall of my apartment (it was going off at 3 in the morning for no apparent reason and wouldn't stop, it's an old Brooks system that is ungodly loud). The wires disconnected before I saw their configuration. I'm trying to reconnect it now. Four wires are coming from the wall, red, black, white and green. The back of the alarm has two clamping plates that you can tighten with a screw. One plate connects to a black wire, the other to a red wire. I know the red wire from the wall was connected to the red wire on the alarm because the tip of the wire was broken off and still connected. I'm assuming the black connects to black. I'm not sure what to do with the white and green wires. Thanks in advance for any insight.
md2lgyk 11-14-2012 05:55 PM
Talk to your landlord. It is generally illegal for tenants to do electrical work on rented property.
k_buz 11-14-2012 05:56 PM
Face the music...call the landlord. If there is a fire and someone is hurt, or the alarm fails because of something you did, you will find yourself in a world of hurt.
sgip2000 11-14-2012 06:10 PM
While true, you should contact your landlord, if there is another alarm in your apartment, you could look at how that one is wired.
Many states are now requiring CO2 alarms as well.
