Hooking Up Ciruits To Service Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2007, 11:37 AM   #1
Hooking up ciruits to service panel
For a licenses electrician: I have a 208A main panel with neutral bars on
either side of the hot bars. The two neutrals are tied together. I am
told that each circuit connecting to the panel must connect the neutral
wire on the same side that I hookup the hot wire to.
Is this right and why?
Bill
dajord is offline   Reply With Quote
Old 04-16-2007, 04:47 PM   #2
Electrician
Rewards Points: 794
Hey whoever told you that is wrong. The neutral bar is the neutral bar if your hots are on the left there is no reason you couldn't put the neutral on the right.
On the other hand there is no reason to do that, it would look alot neater if they were all on the same side of the panel.
darren is offline   Reply With Quote
Old 04-16-2007, 05:20 PM   #3
Darren,
Tahks for your response!
Bill
Old 04-16-2007, 06:11 PM   #4
Where did you get the 208 amp panel. I have never heard of that animal.
Master Electrician
jwhite is offline   Reply With Quote
Old 04-17-2007, 02:10 AM   #5
So Cal Electrician
Send a message via Yahoo to hbsparky
heh 208 amp
hbsparky is offline   Reply With Quote
Old 04-17-2007, 09:31 AM   #6
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
In fact, aren't two or three neutral bars often bridged?
J187 is offline   Reply With Quote
Old 04-17-2007, 05:26 PM   #7
Electrician
Rewards Points: 794
Jwhite that is very good question. I saw that and din't read it all and thought he said 208V, which is possible if you live in an apartment or a condo. But now i know that it says 208A i am curious as well. Do you think he bought a 208A breaker for his main disconnect as well.
Old 04-17-2007, 07:05 PM   #8
I am not gonna say that you could not buy one, but leave your check book at home, you are gonna have to take out a loan to buy that puppy.
Master Electrician
Old 04-18-2007, 04:50 PM   #9
So Cal Electrician
nah, he can just go up to the next size breaker
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 10:00 PM
meter to service panel mikim Electrical 5 05-04-2007 05:34 AM
Arced main lug in service panel burgeke Electrical 4 11-02-2006 11:28 AM
Basement receptacle under service panel mekanic Electrical 2 05-12-2006 05:41 AM
