Hook-up For Elec. Water Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2007, 02:53 PM   #1
Hook-up for elec. water heater
I would like to place a small 12 gal h20 heater (Whrilpool) in the garage.
It will be about 40 feet from my sub-panel. Can I use a 20 amp breaker with 12/2 (dedicated circuit) or do I need a 30 amp breaker with 10/2 wire?
I'm thinking the instructions would most likely tell me but I haven't bought the heater yet as I'm still in the process of building and wiring the garage.
Thanks for any help.
SeanR is offline   Reply With Quote
Old 10-06-2007, 03:06 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
You won't know until you get the heater, or at least the specs.
A small 12gal might very well be only a 20A/120v circuit. Can you look up the specs online?
Old 10-06-2007, 03:56 PM   #3
Hey Speedy, all I know at this time is that it is 120v.
Old 10-06-2007, 07:28 PM   #4
An educated guess would be that a 20A circuit is fine. Most of those smaller 120v units have 1500 watt elements.
Old 10-16-2007, 03:18 PM   #5
WTG
I have a 10 Gal. GE water heater I purchased at Home Depot. It has a 2000w element and requires a 30amp circuit.
WTG is offline   Reply With Quote
Old 10-16-2007, 05:23 PM   #6
Dang, I might be in hot water now (pun intended). The drywall is going up tomorrow. Crapola!
Old 10-16-2007, 05:43 PM   #7
Just go with #10 and you will be covered.
220/221 is offline   Reply With Quote
Old 10-17-2007, 08:20 AM   #8
waiting for spring
arichard21's Avatar
Rewards Points: 150
yes, it cant hurt to go with #10, even if it only requires #12 the larger size is there in case you ever want to upgrade. it would be a smart choice to install the #10 wiring now.
arichard21 is offline   Reply With Quote
Old 10-17-2007, 01:56 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Don't forget the disconnect issue......
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 10-18-2007, 12:39 PM   #10
As per Stubbie, "Don't forget the disconnect issue......"
I don't understand what you mean, Stubbie.
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
