Hook Up Breakers Before Or After Rough In? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 06:10 PM   #1
Hook up breakers before or after rough in?
I'm adding 4 new circuits to my house and will soon schedule the city inspector to come for the rough-in inspection.
Should I hook up my wires to the breaker panel before the rough in, or is that typically done between the rough in and the final inspection?
If I don't hook them up to breakers, do I just leave the wires bunched in the inside panel (whatever it's called, the panel on the other side of the wall from my outside breaker panel).
thx.
bottlerockett is offline   Reply With Quote
Old 07-03-2012, 06:31 PM   #2
Licensed electrician
Rewards Points: 1,610
They can be cut in at any point. If you leave them disconnected from the breakers you can be sure that no one can turn the circuits on before everything is installed.
Old 07-04-2012, 04:17 AM   #3
Typically thet will want to see how / where they enter whatever box they terminate in. If possible.
And that they are stapled / clamped / supported as necessary.
The final connection not necessary yet.
jammin06 is offline   Reply With Quote
Old 07-04-2012, 11:00 AM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Id leave them unhooked in the panel till all your plugs /fixtures are installed
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 07-04-2012, 11:28 AM   #5
ok, thanks all.
Bathroom layout to fit rough in? bryanl Remodeling 6 09-21-2011 08:02 AM
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
Total of Circuit Breakers xraydido Electrical 19 05-13-2010 01:08 PM
Two Breakers for 1 Double Recepticle Box? mfleming Electrical 9 03-10-2010 07:28 AM
