Honeywell Thermostat Model Th8320u1008. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 01:17 PM   #1
honeywell thermostat model th8320u1008.
the thermostat has an led inside the plastic housing that will light up when the system is put into the EM HEAT mode. but, that stupid little led produces some heat when in this mode and that little bit of heat inadvertainly raises the temperature of the thermostat 2 degrees above the actual room temperature; which also happens to be above whatever you had the thermostat set to call for heat;and your thermostat is now inadvertainly set too low for the room temperature that you want the thermostat to maintain !!! how can i eliminate that little led from coming on; wiring wise ????
rdmandme is offline   Reply With Quote
Old 02-16-2013, 01:37 PM   #2
Missouri Bound's Avatar
You don't, and it absolutely is not affecting the thermostats operation. Find your owners manual, you may be able to adjust the themostats calibration.
Do you want it your way or the right way?
The Following 2 Users Say Thank You to Missouri Bound For This Useful Post:
NJMarine (02-16-2013), rdmandme (02-16-2013)
Old 02-16-2013, 02:20 PM   #3
I appreciate you responding; but; that little bit of heat inadvertainly raises the temperature of the thermostat 2 degrees above the actual room temperature.
are you saying that if i have the stat set to call for heat below 72% and the room displayed temp on the stat now shows 74%, the stat will operate properly. It seems to me that if the shown room temp is 74 and i hacve the stat set for 72 it will never call for heat because the room temp now seems to be 74 ?????
Old 02-16-2013, 03:27 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Im pretty sure Honeywell knows how to make a tstat... For whatever reason, your heating system is over shooting the desired temperature setting. Probably the tstat is not set up correctly...
The Right Thermostat? (Honeywell says two diffrerent things) FourIsWaltz HVAC 3 10-10-2010 08:20 PM
New Honeywell thermostat connected to old Climatrol heat pump olorintf HVAC 0 08-24-2010 09:52 AM
Need help with Honeywell thermostat mmspar HVAC 1 06-29-2010 10:29 PM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 09:56 AM
Honeywell Electric Thermostat Model T498 staylori HVAC 1 01-14-2006 12:25 PM
