Honeywell Thermostat Buzzing - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2008, 08:38 PM   #1
Hi,
I just purchased a home (approx. 1 year old) which has the dial-type Honeywell thermostats installed. I've noticed on the majority of them, that when they turn on, there is a buzzing / vibration noise that lasts for 30 seconds or so. If I happen to touch the dial part of the thermostat, the buzzing stops.
I have two questions: What is causing the buzzing noise? Are the thermostats safe to operate in this manner.
Thank you.
kbuckle is offline   Reply With Quote
The Following User Says Thank You to kbuckle For This Useful Post:
bernds (07-06-2016)
Old 12-29-2008, 11:14 AM   #2
The first step would be to check on the furnace itself to find a contractor sticker. The company that installed the unit should be listed there - the system might still be under warranty?
The second step would be to look into getting a newer programmable energy efficient style thermostat. Not sure whats causing that buzzing but it does not give me very secure feeling. New thermostats are pretty reasonable and you'll save a good amount on your power bills as well.
At the same time you might want to establish a good rapport with a local HVAC company for at least bi-annual service calls to save you issues in the future. Hope thats of some help.
Skipperjj is offline   Reply With Quote
Old 12-29-2008, 12:17 PM   #3
Rewards Points: 1,442
Can you take the cover off the thermostat and see all the parts inside? Can you duplicate the situation by turning the dial ever so slowly one way or the other? I cannot think of any reason why the old round non-programmable mercury Honeywell thermostats would hum. Except possibly due to age of the bimetallic strip it took time for the glass capsule to tilt just right and the glob of mercury stopped halfway and an arc occurred in the capsule.
Old 12-29-2008, 03:34 PM   #4
Thanks for the comments. I have tried unsuccessfully to repeat the scenario with the cover removed. As I stated in the initial post, when I touch the dial, the buzz/hum stops.
I have also replaced the thermostats with programmable type in the main living areas, but maybe it's time to change them throughout the house.
I should have mentioned earlier that the home has baseboard heaters and not a furnace has suggested in one of the replys.
Old 03-08-2009, 01:01 PM   #5
Dangerous
Mine does the same thing, I touch it or hit the wall near it, it stops. I have an identical one in the other room that only has done it twice all winter, this one does it multiple times a day. So you are not alone!
BennettCKM is offline   Reply With Quote
Old 03-08-2009, 03:08 PM   #6
Could there be a loose connection inside, perhaps where the wires in the wall are attached to the thermostat?
For non-mercury models could the actual contact be dirty? You can use a small piece of ultra fine sandpaper or crocus cloth to clean the contact.
Old 07-06-2016, 03:45 AM   #7
Rewards Points: 2
Angry
Re: Honeywell Thermostat Buzzing
In our company, we have these in every room (4 Floors, 6 rooms each).
They are ALL behaving in this way (not only 30secs, partially over 5 minutes long). They make this buzzing noise frequently and it is incredibly annoying.
It is not an exception that they show this defect, they ARE defective.
Is there anyone who has tried something to stop it and can say he found a solution to this issue?
bernds is offline   Reply With Quote
Old 07-06-2016, 03:51 AM   #8
dmxtothemax's Avatar
Rewards Points: 5,102
Has anyone contacted Honeywell and asked for there advice ?
dmxtothemax is offline   Reply With Quote
Tags
buzzing , honeywell , noise , thermostat , thermostat help
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 03:11 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Honeywell VisionPro Thermostat infoskr HVAC 32 12-17-2008 04:44 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 02:30 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
