Homeowners Electrical Test - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2012, 09:54 AM   #1
homeowners electrical test
where can i take my homeowners electrical test in st.louis,mo.
derek stevens is offline   Reply With Quote
Old 07-13-2012, 10:30 AM   #2
Rewards Points: 1,294
What is a homeowners electrical test????? If there is one I would imagine you would take it in St. Louis
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
jimmy21 (07-13-2012)
Old 07-13-2012, 11:43 AM   #3
Rewards Points: 3,256
I had to take mine at the county electrical permitting office.
zappa is offline   Reply With Quote
Old 07-13-2012, 04:17 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Let me ask you this. What do you think is a better idea; asking this question to a message board on the world wide interwebs, or calling your local building department to ask??
Old 07-13-2012, 04:31 PM   #5
MarginallyQualified
Rewards Points: 2,464
when you get a copy of it... post the test here
Old 07-13-2012, 04:43 PM   #6
This is sample questions from Mecklenburg County NC
Homeowner Sample Exam Questions 1) What would be the net calculated load in volt amps of a dwelling unit with a floor area of 1500 sq. ft. including an unfinished cellar not adaptable for future use, unfinished attic, and open porches. Appliances are a 12-KW range and a 5.5-KW, 240-V dryer. Assume range and dryer KW ratings equivalent to KVA ratings in accordance with 220.54 and 220.55.
a) 17,600 VA
b) 17,100 VA
c) 18,600 VA
d) 18,100 VA
See Answer
2) How many outdoor convenience outlets excluding the A/C units are required for a dwelling unit that is 4867 sq. ft. with a detached garage on a quarter acre corner lot?
a) one
b) two
c) three
d) none
See Answer
3) How many 15 amp general use circuits are required for a single family dwelling unit 3120 square feet that has a full kitchen, 2 bathrooms, a living room, and 4 bedrooms each with a walk in closet?
a) 2 circuits
b) 4 circuits
c) 5 circuits
d) 6 circuits
See Answer
4) Which of the following locations are you not allowed to install overcurrent devices?
a) Hallways
b) Bedrooms
c) Clothes closet
d) Storage room
See Answer
5) All of the outlets in a single family bedroom are required by the NEC to be protected by arc-fault devices. Which of the following items are not required to be protected by arc-fault devices?
a) Switch for exterior flood lights
b) Ceiling fan
c) Wall outlets
d) Lighting fixtures
M Engineer is offline   Reply With Quote
Old 07-13-2012, 07:21 PM   #7
Master Electrician
what's the purpose of this test? Up here your either an electrician or your not.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-13-2012, 07:40 PM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Same here, what is the purpose of this?
Old 07-13-2012, 08:05 PM   #9
some localities allow you to work on your own home with 2 caviots. you get a permit and pass a homeowners electrical test. then again some require no test but a permit and inspection
bf514921 is offline   Reply With Quote
Old 07-13-2012, 08:20 PM   #10
MarginallyQualified
Originally Posted by bf514921 View Post
...then again some require no test but a permit and inspection
The test is to determine if YOU are capable of doing the work on your own vs hiring the guy who got laid off by some local EC and then chatted you up in the parking lot at Home Depot and would probably have done the job if you had signed the contract with his former employer last week.
Here (iirc) they have some VERY simple questions on a sheet but mostly talk to you a bit and try to find out if you're a complete idiot or not. When I got my mechanical permit I had to spend 5 minutes explaining to the guy that yes, there is in fact a difference between an updraft gas furnace and an air handler and that no, everything connected to a condensing unit isn't necessarily a heat pump.
iow... the knife cuts both ways.
Old 07-13-2012, 09:55 PM   #11
Davejss's Avatar
Rewards Points: 740
Hot's on the left, cold's on the right, and crap don't float uphill. No wait...that's the homeowner's plumbing test. Nevermind.
Davejss is offline   Reply With Quote
Old 07-13-2012, 10:47 PM   #12
Rewards Points: 29
ROFLMAO.
It will if you push really hard!
I mean with a pump. ;-)
philmy is offline   Reply With Quote
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 12:16 PM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 08:46 PM
Electrical Inspector Permitting problems zedman Electrical 27 11-27-2009 12:56 PM
Electrical feedback coming through electrical system..Did it fry my laptop? CTroxtell Electrical 14 11-21-2009 05:36 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
