Homeowners. Don't Be THAT GUY. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 04:51 PM   #16
Rewards Points: 900
This is just one more example of why a DIY'er should have to pass at least a basic electrical test before being allowed to do anything!
Problem is, who is going to administer the test, and who is going to enforce it??
Not being a licensed electrician myself, but knowing plenty about electricity, and respecting the code, I would have absolutely no problem if I were told that I needed to take and pass such a test.
The worst part about this is that the guy may do his own, lousy work and it will function for years, then he sells the house to the poor, unsuspecting guy and finally something like what happened here does happen, and the new owner is stuck with it.
If everyone had inspection as needed, nothing like this would happen, but again; who is going to enforce this?
Ultrarunner2017 is offline   Reply With Quote
Old 01-17-2009, 05:07 PM   #17
And how are you going to prevent a DIY from doing work, not getting it inspected & not taking a test? You would never be able to enforce this. Here we are allowed to do our own work. The Inspector has the option at inspection of failing & making you then hire an electrician to correct the problems that were flagged. I welcome the inspection process, so far just had to add secure flex line to my pool pump
The harder you make it, the more people will avoid the proper way & inspections
I've had more then one instance where the Inspector had to review the codes & then get back to me to approve the wiring I wanted to do (right out of the code book). I didn't mind the wait - just a few hours & they clarified I could do what I wanted - but they wanted either 2 trenches with UF, or one trench with conduit (2 circuits). It was easier to do 1 trench & conduit
Old 01-17-2009, 05:56 PM   #18
Rewards Points: 900
No mind; I'm just ranting.
Old 01-17-2009, 06:16 PM   #19
I know the feeling
I'm on another site where a guy outlined how he was going to wire something. The correct way to wire was pointed out as Code
His reply was tell me why I should wire it that way & please just don't say because code indicates it has to be wired that way
Old 01-17-2009, 06:39 PM   #20
Rewards Points: 270
Exactly. I can barely change a light bulb without getting a permit. Does that make me want to go out and get a permit... no.
Code does not always make sense for everyone either and it's possible in certain instances to go against code and be perfectly safe.
pcampbell is offline   Reply With Quote
Old 01-17-2009, 06:47 PM   #21
Don't get me wrong, I believe in permits & inspections
I don't need a neighbor pulling a bonehead move & starting an electrical fire & burning my house down too
Going against code doesn't even come into play, that is simply wrong
If you don't know the code then it is your job to find out & wire correctly
Old 01-17-2009, 10:41 PM   #22
DIYer
Originally Posted by Yoyizit View Post
Actually, one out of 12 "units" failing after 8 years is not a bad MTBF,
Did you used to work for NASA?
Gigs is offline   Reply With Quote
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 06:48 AM
Owens-corning duration 30 yr DaveS Roofing/Siding 17 12-16-2010 06:42 AM
Help!!construction Of Slab Wrong!!new Homeowners massonj@embarqmail.com Building & Construction 18 07-19-2007 06:46 PM
New Homeowners getting a flood in there dineing room Gerardinejb Roofing/Siding 2 06-07-2007 10:22 AM
To all homeowners robertcdf General DIY Discussions 23 01-16-2007 04:57 PM
