Homeowners. Don't Be THAT GUY. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2009, 04:53 PM   #1
Homeowners. Don't be THAT GUY.
You know the guy. He cuts an opening in a patition wall, finds a bunch of cable and he figures he can just splice/tape them.
He had twelve splices in this wall. It worked for 8 years and recently he started to smell pine burning.
Had to tear out all the paneling and drywall.
220/221 is offline   Reply With Quote
Old 01-14-2009, 05:04 PM   #2
Why did it work for so long?
Why did it stop working?
Were the splices soldered?
How many of the 12 failed?
Old 01-14-2009, 05:23 PM   #3
Licensed Pro
Is that Al wire? Looks like an AL-CU splice that failed (duh!)
Old 01-14-2009, 05:57 PM   #4
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 818
Looks like he's also the guy that doesn't know how to frame an opening. He installed the jack studs wrong. And I don't see any cripple studs. Before or after. And hopefully those two new electrical boxes will have access covers and not be hidden behind the drywall.
Aggie67 is offline   Reply With Quote
Old 01-15-2009, 05:15 AM   #5
Bad connections get progressivly worse over time. The more carbon crap, the more resistance.
It finally reached critical mass
Heh heh...no
One
It is AL wire but the failure was because of a loose/bad connection, not an AL/CU connection.
He didn't even need the header. It only a partition wall. He didn't know any better.
Old 01-15-2009, 05:55 AM   #6
elect, contractor
Rewards Points: 27
This guy is lucky he still has a house where it can be fixed and not a very large pile of ashes
Good job 220/221 only about a million more of these to fix.
ACB Electric is offline   Reply With Quote
Old 01-15-2009, 02:40 PM   #7
Heh heh...no
One
Actually, one out of 12 "units" failing after 8 years is not a bad MTBF, and this is a guy who made the splices with average or less-than-average "diligence".
If you started out with 12 brand new cars, how many would have "failed" in less than 8 years?
The problem with house wiring in houses made of wood is the possible bad consequences of just a single failure.
While we're on the subject,
roughly how many wires nuts are there in an average house?
How many splices of this kind fail, per year, or per 10 years?
In my whole life I've never knowingly had a splice fail in a house I've lived in, so a diligently done wirenut connection must have a very low failure rate.
Old 01-15-2009, 03:59 PM   #8
What is the correct way to do that? In a box?
jweller is offline   Reply With Quote
Old 01-15-2009, 04:10 PM   #9
Res Ipsa Loquitur
Either place a new box for the junctions and use a blank cover to make it less obvious (of course with accessibility) or run new cables between the existing boxes.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 01-15-2009, 04:22 PM   #10
Ok so exactly what I thought it was. Good to know.
Old 01-15-2009, 05:02 PM   #11
The purpose of the box is to contain the fire in a failure situation.
Splice will fail. That's why you leave them protected and accessible.
Todays failure. No smoke, simply a failed connection. a single #12 in with 2 #14's. They weren't diligent and it came loose after a few years after the remodel.
Old 01-15-2009, 08:42 PM   #12
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
Damn!
Magnettica is offline   Reply With Quote
Old 01-15-2009, 09:37 PM   #13
DIY
Rewards Points: 150
What??? 8 years is not a bad MTBF electrical connections?? By that logic, my house should have burned down at least 10 times by now...
gp_wa is offline   Reply With Quote
Old 01-16-2009, 06:18 AM   #14
elect, contractor
Rewards Points: 27
wow,,, seems a certain failure rate is acceptable by some.
it can be expected but everything posible should be done to avoid disaster which in most cases is covered if the electrical code is followed to the letter, and acceptable would be more like 1 in one million over 8 years.
My cousin is a 31 year vetrin fire fighter (volenteer), he has seen some nasty sh*t over those years but one thing that struck him hard a couple years ago was after a fire was extinguished which wiped out an entire house, was finding the family ( whom our family knew) both parents still in bed, one child still in what was a crib, and other two children in a corner of their room huddled together, all died of smoke inhailation before they were burnt to a crisp, they bought the house 4 years before, the father knew nothing and did nothing electrical, the home passed a home inspection at the time of sale. the fire was caused buy pretty the same thing, burried electrical connections (no box) in a basement ceiling (wreckroom) done by the previous home owner, done several years before he had sold the house.
Does that make the failure rate still acceptable, or doing it wrong still acceptable?
Old 01-16-2009, 03:51 PM   #15
No, it's 12x8 = 96 years. MTBF calcs. are rather weird, and some people don't believe in them at all, including "The Bathtub Curve."
And since a car has thousands of parts, for a whole car to last 8 years requires each part to have a virtually zero failure rate.
For people safety there are very high reliability rates, I think 99.9999% or something. I used to know what it was for the Space Shuttle.
MIL-STD 217 covers this subject.
Let's say birth control is 99.9% effective. You "throw the dice" 1000 times. There's a 1-[0.999^1000] = 63% chance you'll be buying baby clothes.
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 07:48 AM
Owens-corning duration 30 yr DaveS Roofing/Siding 17 12-16-2010 07:42 AM
Help!!construction Of Slab Wrong!!new Homeowners massonj@embarqmail.com Building & Construction 18 07-19-2007 07:46 PM
New Homeowners getting a flood in there dineing room Gerardinejb Roofing/Siding 2 06-07-2007 11:22 AM
To all homeowners robertcdf General DIY Discussions 23 01-16-2007 05:57 PM
