Homemaker---fan Install - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2011, 03:15 AM   #1
Homemaker---fan install
I am installing a hunter low profile 42 inch ceiling fan model 21880. The directions leave me with a half inch gap between the housing and the ceiling
Help. Can't see how to correct this following directions
Healthnutmom is offline   Reply With Quote
Old 08-05-2011, 06:04 AM   #2
If the fan rated J box is correctly mounted, flush to or slightly above the drywall surface, all should mount according to their directions.
Old 08-05-2011, 10:59 PM   #3
Rewards Points: 5,336
You need to explain the situation you have that won't allow the proper installation of the fan.
Are you using the correct code proper fan box or are you trying to install it in the box the light was attached to?
Ron
B. Franklin 1759
Old 08-06-2011, 01:17 PM   #4
zpm
yeah, right
Seems like you're not the only one with the problem.
This from amazon.com
This review is from: Hunter 21880 Low Profile 42-Inch 5-Blade 3-Light Ceiling Fan, White with Bleached Oak/White Blades and Frosted Glass Shades (Tools & Home Improvement)
This was a low priced item and we were less than pleased with the "fit and finish". It was labeled as a "ceiling hugger" and however, after installation, there was gap between the ceiling and the fan body. The canopy screws were also exposed. Most ceiling fans I have installed come with a plastic ring to cover the mounting screws and fill in the gap between the fan body and the ceiling. This one did not and looked "unfinished". I was pleased with Amazon service and the quick response to our request to return the fan.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
Fiberock install STUPID Flooring 5 10-16-2007 06:29 PM
