Homeline Grounds/Subpanel Addition - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-17-2007, 10:16 PM   #16
jproffer's Avatar
Rewards Points: 714
the gas line is in a pvc type pipe also.
Don't mean to get off topic here, but that will need to be changed. In most places you can't run gas (LP or natural) in PVC pipe. (in fact noplace I've ever heard of allows that, but I haven't been everywhere)
So after you have the correct type of pipe (black pipe) for your gas line, the answer to jwhite's question will be yes.
EDIT: Reread what you said...and if you mean the correct type pipe is inside of another length of PVC, then I will retract part of what I said. Either way, the answer will be, or already is...yes.
jproffer is offline   Reply With Quote
Old 04-17-2007, 10:56 PM   #17
yeah it was ran in a yellow type flexible pipe and then it goes to the black pipe.
aarons600rr is offline   Reply With Quote
Old 04-18-2007, 05:07 AM   #18
The tv and phone wires themselves are metal paths. It does not matter that they are inside a pvc pipe.
You need a four wire system. Three number six and one numbrer 10 ground.
Master Electrician
jwhite is offline   Reply With Quote
Old 04-18-2007, 05:47 AM   #19
That yellow flexible gas tubing is metal, with a plastic sheath. But it sounds like there are already plenty of metal paths between the buildings.
NateHanson is offline   Reply With Quote
Addition "shell" cost per square foot - is this reasonable? ourzoo Building & Construction 21 12-20-2011 05:22 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
framing in roof over addition What have I done Building & Construction 1 05-25-2007 07:50 PM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 07:59 PM
kit metal building as addition structure weaver Building & Construction 9 08-08-2006 09:59 AM
