Home Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2012, 07:47 PM   #1
Home wiring
I live in a three year old house. I added a new outlet, switch, and a exterior light. Everything seems to be working fine. But I would like a little reassurance that I did it right. So I ran 12/2 from an existing outlet in the ceiling that the garage door opener plugs into to the new outlet (pigtailed on both outlets) then to the switch then to the exterior light. Also is it ok to lay the wire on top of the insulation in the attic? There is big grouping of wires coming from the panel running up through the attic and they seem to be warm to touch. Is this ok?
Mill is offline   Reply With Quote
Old 05-21-2012, 10:09 PM   #2
Rewards Points: 6,652
It depends on how warm the attic is right now. Mine gets up to about 101 on a nice sunny day, so everything up there is going to be warm to the touch.
The Following User Says Thank You to gregzoll For This Useful Post:
Mill (05-22-2012)
Old 05-22-2012, 10:19 AM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Romex is constructed with 90C conductors so it can withstand the heat. The problem is when it is bundled together with lets say wire ties, or ran in the insulation. Then it has to be derated. If your cables are laying loose across the attic there shouldn't be a problem.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Mill (05-22-2012)
Old 05-22-2012, 12:20 PM   #4
Thanks for the response. Now do you think the wiring I ran should be ok?
Old 05-22-2012, 01:04 PM   #5
kevinp22's Avatar
Mill,
From what you say your work does not raise any red flags. However, if you really want the reassurance from folks on this board we need:
1. pctures (inside of boxes would be nice)
2. description of what circuit was tapped into
the job, done correctly, means:
1. properly designed (you tapped a circuit that is not already overloaded and that is not restricted for example bath circuits cant serve non bath loads)
2. you used code-compliant UL listed boxes, wires and cables/conduit, switches, lights and receptacles as appropriate. the light is rated for outdoor use and the receptacle is a GFCI
3. your work is of good quality. For example, if your connections are not well made or you didnt connect grounds properly you will have problems regardless of how well designed it is and the materials used. Also many people on this forum hate back-stabbed receptacles and switches but since I never use them I have no opinion
kevinp22 is offline   Reply With Quote
The Following User Says Thank You to kevinp22 For This Useful Post:
Mill (05-22-2012)
Old 05-22-2012, 01:58 PM   #6
I will try to post some pictures. All material is code compliant. All the connections are secured with wire nuts and twisted together before I put on the wire nuts and are not back stabbed they are secured to the screws. Why do you need a gfci is it because the light is powered from this outlet?
Old 05-22-2012, 02:32 PM   #7
kevinp22's Avatar
GFCI is if the outlet is a general use receptacle in the garage. It was my understanding from your post you installed a new general purpose receptacle and a switch with corresponding light outside. If you did not install a general use receptacle I misread and you can disregard the gfci note.
Mill (05-22-2012)
Old 05-22-2012, 03:02 PM   #8
I did not use a gfci. All of the other receptacles are general use in the garage is this ok? Would you hook up a gfci the same as a general use one?
Old 05-22-2012, 05:15 PM   #9
kevinp22's Avatar
The 2008 NEC revision to article 210.8(A)(2) did away with the exceptions for dedicated outlets (e.g., freezers, irrigation controllers, etc.) and for inaccessible outlets such as those in the ceiling for garage door operators. Basically, if it's in the garage, it must be GFCI protected.
If your garage was built under a previous code cycle, it may well not have been required. However, since you are adding a new one/changing the wiring, it would be wise to check code in your area.
Or ask your inspector, since you pulled a permit for this, right?
Old 05-22-2012, 06:39 PM   #10
Some areas do not require permits to be pulled, if the homeowner is doing the work. Mine does not, as long as you perform the scope of the work in a professional manner and follow the NEC & city rules regarding electrical codes.
Ravenworks (05-22-2012)
1938 TN Home - My First Home, My First project, Tons of Pictures!!! Firefighter3244 Project Showcase 78 07-01-2014 11:55 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
fixing old wiring in 40's bulit home with rock lath pacifier1er Electrical 2 12-15-2009 07:31 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
Home Wiring CAD Software fw2007 Electrical 4 02-11-2008 12:30 PM
