Home Theater Wiring Question : Separation - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 05:13 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Home theater wiring question : Separation
I understand the importance of separating the 110/220 V wiring from audio cables to reduce the chance of noise and other interference, but I am wondering if it is equally important to separate the signal cables (RCA) from the speaker wire themselves, or can I run these together? Obviously they go to the same location anyway on one end.
TYIA
Journeyman Plumber
Old 10-07-2012, 07:34 PM   #2
Rewards Points: 6,652
The low voltage wiring can all be next to each other. Majority of the time, RG-6 is used for all audio & Component wiring, Cat-6 is used for HDMI these days.
Old 10-07-2012, 08:00 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I wouldn't worry about keeping anything separated...
Old 10-09-2012, 04:01 PM   #4
Rewards Points: 186
The only thing I would worry about is if you are running low level analog signal cables, i.e. RCA, VGA, component, composite tightly bundled with 120v wires for an extended distance, i.e. >5 feet. I worked installing home theatres, and we would run into issues very rarley, but sometimes with analog video (i.e. not HDMI, DVI etc...) when we would do a TV mounted over a fireplace etc... and the power cables were running with the analog video cables for most of the run.
But today most video is digital, so it either makes it there or it doesn't, so don't worry about it for video if you're doing digital. Speaker cable is basically impervious to noise. What you have to worry about is the very low voltage audio, i.e. running sources from the house out to a pool house (long runs) with high voltage power (not speaker) right next to it. But then again if you're outside, it probably doesn't matter if you get a little less fidelity, it's not going to be a big deal.
Don't worry if you're just running wires across each other in a home theater situation, but don't run low voltage analog signals parallel with power for >5 feet.
That's my $.02 from working as a whole house/theatre tech for a few years in college.
Ocelaris is offline   Reply With Quote
Old 10-11-2012, 11:13 AM   #5
TYIA
The other answers about not needing to worry are right. Put a couple article website links thought you might find useful. Let me know if I can help out. The last link is just a "just for kicks link"
Surround Sound - AVR: http://allabouthomeelectronics.com/s...at-is-avr.html
Connection Cables: http://allabouthomeelectronics.com/c...on-cables.html
Everet is offline   Reply With Quote
Home Theater In-line fan / Damper Control fax6202 HVAC 11 07-27-2012 11:03 PM
Blu Ray Home Theater? cbzdel Home Theater 8 05-16-2010 03:03 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
Adding additional wiring to new block home sailorman Electrical 6 05-28-2009 02:27 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 06:44 AM
