Old 10-26-2012, 06:32 PM   #1
"Old" Newbie
Home Temperature Monitoring
I need to be away from my house in northern New England for extended periods of time during the winter and am concerned about the possibility of pipes freezing, etc. in the event that for some reason my furnace goes out.
I am intrigued by several temperature monitors that would call me in the event the temperature dropped below a prescribed level. I've written to manufacturers with the following question but have received no response.
Will any of these systems work if there is no phone "land line" in the house?
We have television and internet hook-up through our local cable company but our phone service is cell phone only.
Sure would appreciate it if anyone has had experience with a situation like this. Thanks, Rob
RCrosby257 is offline   Reply With Quote
Old 10-26-2012, 06:46 PM   #2
Lic Electrical Inspector
electures's Avatar
If you have an alarm system, you can use a tempature switch and assign it to a zone. Then tell the monitoring service to contact you and any contractor you designate. Honeywell also has some alarm systems that will work. You can also look into a NEST t-stat. which utilizes a wifi connection.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 10-27-2012, 08:59 AM   #3
There are monitors that use a light plugged into them, that if temp drops below setpoint the light will turn on.Just need to be on good terms with your neighbors so they would actually call if there is a problem.Also have seen a honeywell t-stat at Home Depot that has wi-fi features.$149.00. $100 cheaper than nest.Nest is overrated if ya ask me.
HVACTECH96 is offline   Reply With Quote
Old 10-27-2012, 10:44 AM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
A friendly neighbor as a caretaker is the best and cheapest option.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General Discussion 24 05-19-2011 08:23 PM
how to stop condensation on windows? cake General Discussion 7 11-22-2008 01:12 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
