Home Run To Wall Switch Or Ceilng Box - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2008, 06:21 PM   #1
Rewards Points: 77
home run to wall switch or ceilng box
On a new lighting circuit, is it generally preferred to take the home run to the light fixture ceiling box or take the home run to the wall switch box?
In a kitchen, does the disposal and dishwasher need to be gfci protected, or just the small appliance outlets?
SS396 is offline   Reply With Quote
Old 12-29-2008, 06:37 PM   #2
Rewards Points: 2,350
I prefer to take the home run to the switch box, as it is easier to work there than on a ladder overhead. But either method is legal.
No, the disposal and dishwasher do not have to be GFCI protected unless there is a local ordinance requiring it. The two small appliance circuits must be GFCI protected.
Old 12-29-2008, 07:33 PM   #3
joed's Avatar
Rewards Points: 12,904
I take the home run to which ever is closer to the panel box, the fixture or the switch. Why use extra going and coming back?
Old 12-29-2008, 08:26 PM   #4
ALWAYS to the sw box. When you are making up or troubleshooting, the sw boxes are always the most accessible boxes. I typically wire most everything sw box to sw box.
No ladders involved, no fixture/fan removal. Nothing is ever in the way of a switch......unless it's a storage room packed with crap.
Back in the 70's we would make up spiders in the shop. Deep ceiling box with 4, 2 wire cables and one 3 wire cable about 15' long. We'd nail up the ceiling box in the bedrooms and drop the cables down to the receps and switch. Add a home run and a couple jumpers and you were done in minutes. The drawback of course was having a wad of wires in the light JBox. Someone uses a couple of 100 watt A lamps for a decade and you havd a mess to deal with.
220/221 is offline   Reply With Quote
Old 12-29-2008, 09:36 PM   #5
Licensed Pro
SW box, for all the reasons 220 just listed.
Old 12-29-2008, 09:55 PM   #6
Licensed Builder
Yes, I was taught to always run the home run to the SW box because if you run a 14-2 home run to the light then you have to run a 14-3 down to the switch because you MUST have both a ground and a common in the sw box.
Why waste the 14-3?
Rustaholic is offline   Reply With Quote
Old 12-29-2008, 10:10 PM   #7
Not really......but it's always a good idea.
BTW, any wire installed is not wasted. I'm a big fan of extra wire as I do a lot of remodel stuff. When you are adding cans, how cool is it to find a 3 wire switch leg with the red as a spare.
When I do special jobs I always run 3 wire switch legs for future.
Old 12-30-2008, 02:24 PM   #8
joed's Avatar
All of the above posts are OPINIONs. Either way is proper under the electrical code.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Fluorescent lamp requires wall switch to be cycled several times before lighting. joejean Electrical 5 09-04-2008 08:48 AM
Can lights, wall switch and BX (in Chicago) alvanos Electrical 7 03-02-2008 08:48 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
