Home neutral wire attached to neighbor
Gizmo, it is not Postive & Neutral. You have a Ac or Alternating Current system, which means that you would have a single leg of 220 volts, then the Neutral or 110 volt & Neutral. Grounding is usually done as a Ufer due to soil conditions, and that some areas may not have a deep enough soil structure to get a 8 foot ground rod into. See http://www.bohol.ph/article68.html This will also give you another person that is in the PI their perspective of the electrical system http://myphilippinelife.com/our-phil...trical-wiring/
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
