Home Inspector Says GFCIs Are Not Wired Correctly!!! - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 08:37 PM   #31
Chicago, IL
Michael Thomas's Avatar
Originally Posted by Speedy Petey View Post
The mere fact that this is a kitchen, and he requested removing the GFI and installing a standard 3-prong receptacle, on an ungrounded circuit speaks volumes for his ineptness.
Quite possibly the inspector was incompetent, but experience has taught me that to made the determination you need to know *exactly* what was listed as a defect, and what was recommended as a correction.
BTW, some older GFCI's will sometimes fail in a manner such that they will "trip" (the reset button will pop out) but will remain energized, which I why you can NOT rely exclusively on the internal test function. I catch one or two of these a year with my "unnecessary" tester.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 12-16-2010, 09:04 PM   #32
Rewards Points: 81
Originally Posted by a7ecorsair View Post
When you added the additional outlets, did you pull a new cable from the panel or did you just tap into the old wiring?
If you tapped into the old wiring did you add the original outlets to the load side of a GFCI?
Are all the outlets in the kitchen GFCI protected?
I added a completely new circuit from the panel into the kitchen when I added circuits. All outlets have GFCIs except one or two and those outlets are on the load side of the upstream GFCI and are protected.
hartkem is offline   Reply With Quote
Old 12-16-2010, 09:07 PM   #33
Rewards Points: 81
All the GFCIs are new and the circuit does not remain energized. I changed them before I left to make sure I didn't have any problems. If you remember his corrective action to me verbally was to install regular three prong outlets in there place.
Old 12-16-2010, 10:14 PM   #34
Chicago, IL
Well, that's completely wrong, of course. Sorry you have to deal with it.
Old 12-16-2010, 10:19 PM   #35
Rewards Points: 590
He stuck to his guns that the GFCIs would not work properly without it and then said he won that argument in court.
I could have beaten him handily with a photocopy of one page of the NEC-- and I'm not an electrician.
operagost is offline   Reply With Quote
Old 12-16-2010, 10:27 PM   #36
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by SGC622 View Post
yes but if he found the first outlet on the circuit and put a GFCI on it the rest would be covered and it would be compliant.
No, it wouldn't. Not if he actually extended (read: added anything to) the circuit. You cannot extend a non-compliant circuit. It is that simple. It doesn't matter if every recep had a GFCI on it, it would still not be legal because you cannot extend a non-compliant circuit, period.
Old 12-16-2010, 10:30 PM   #37
nap
You talking to me?
nap's Avatar
so, the GFCI's of concern were existing receps? You simply added the GFCI protection, right?
and any receps with no ground but are GFCI protected are stickered as no ground and GFCI protected?
Old 12-17-2010, 07:59 AM   #38
The inspector may be wrong, but your goal is to sell the house. Were it me, I would ask the buyer to get his choice of a licensed electrician to give an estimate of what it would cost to fix the problem (whatever that problem may turn out to be in the electrician's professional opinion) and negotiate the selling price with that estimate factored in.
Pistol Pete is offline   Reply With Quote
Old 12-17-2010, 01:03 PM   #39
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Originally Posted by Pistol Pete View Post
......, I would ask the buyer to get his choice of a licensed electrician to give an estimate of what it would cost to fix the problem (whatever that problem may turn out to be in the electrician's professional opinion) and negotiate the selling price with that estimate factored in.
OK fine. What if there is NO problem? Who pays then?
Speedy Petey is online now   Reply With Quote
Old 12-17-2010, 01:25 PM   #40
RST
DIY Homeowner
Rewards Points: 150
Could someone define "non-compliant" circuit? Is it any circuit that doesn't comply to the latest NEC?
RST
RST is offline   Reply With Quote
Old 12-17-2010, 01:33 PM   #41
Licensed electrician
Rewards Points: 1,872
RST
One that I can think of right now is from the late 80's. The bathroom receptacle circuit could be 15 amps and GFI and be shared with exterior receptacles. Now it needs to be 20 amp, GFI and only serve bathroom receptacles OR one bathroom.
Some garage and unfinished basement receptacles did not need GFI protection, now they do.
Older circuits for dryers and stoves were allowed to be fed with 3 wires. Now it must be 4 wires. Feeders to outbuilding are now the same way.
RST (12-17-2010)
Old 12-17-2010, 01:38 PM   #42
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
RST
It is based on the code at the time of installation.
Remodels could trigger current codes to be applied.
An example of a compliant circuit is a 3 wire feed to a stove or dryer.
As long as these items are not relocated, they are still ok, but if moved, will trigger the latest code, whitch requires 4 wire
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
RST (12-17-2010)
Old 12-17-2010, 01:49 PM   #43
If there is no problem, then there is either no cost, or a nominal cost for the advice from an electrician. How much could that be? Less than $100?
While you may have the moral authority to insist that the prospective buyer pay such costs, are you willing to risk loss of the sale for a hundred dollars?
oberkc is offline   Reply With Quote
Old 12-17-2010, 02:03 PM   #44
IMO the HI should have to pay because HE is the one who insisted that a problem existed where none did.
And we all know that buyers take a HI's word as gospel.
Old 12-17-2010, 02:45 PM   #45
Maybe, but I don't feel the need to pay someone good money needlessly. I feel bad when an HI makes someone spend money to refute one of their "defects" like this that is not an issue even when I make money on it.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
frenchelectrican (12-18-2010), jbfan (12-17-2010), Speedy Petey (12-17-2010)
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 08:15 PM
Insulateing a Home Rifeman Building & Construction 9 08-31-2007 04:28 PM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 08:44 AM
Home Improvement/Remodeling Contractor Website Possibility? newigal General DIY Discussions 6 01-03-2006 09:38 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
