Home Gas Furnace Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 12-15-2012, 03:26 PM   #1
Rewards Points: 125
home gas furnace problems
In a home gas furnace sometimes the igniter glows and the gas kicks in the furnace igniting . Sometimes the igniter wont glow at all the furnace not starting. I have replace the electrical circuit panel/board and I have replaced the igniter. Why isn't the igniter glowing every time?
debd is offline   Reply With Quote
Old 12-15-2012, 04:09 PM   #2
Rewards Points: 1,300
Is the draft inducer motor starting? If it is the pressure switch connected to it with a small vacuume tube may be bad. The ports on it also may be clogged. Next time the furnace won't start check to see if there is 24 volts on both sides of the switch on the pressure switch. Check this to ground. Sounds like this might be the problem.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
NJMarine (12-16-2012)
Old 12-15-2012, 10:58 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Because something is telling the control board to not allow the igniter to light the gas and probably not allowing the gas to flow either.
What is the make and model of your furnace?
Old 12-16-2012, 02:48 PM   #4
Rewards Points: 125
Goodman
GDS 80703AXBB
Old 12-16-2012, 03:25 PM   #5
Rewards Points: 125
Yes, both post show full current. Does this mean the pressure switch is good or is there a change it is still bad?
Old 12-16-2012, 04:16 PM   #6
What voltage did you see when you tested?
Old 12-16-2012, 04:31 PM   #7
Rewards Points: 125
Its reading 20 volts
Old 12-16-2012, 06:42 PM   #8
Have you been able to get a reading when the furnace does not lite? 20 is a little on the low side but should work. Idealy 24+ is better.
Old 12-16-2012, 07:07 PM   #9
Items wanted: Time
Rewards Points: 150
20 volts is not enough, check the voltage across the pressure switch during the start of the heating cycle, should be 0, switch is closed, 24 and switch is open.
NiNe O is offline   Reply With Quote
The Following User Says Thank You to NiNe O For This Useful Post:
NJMarine (12-17-2012)
Old 12-21-2012, 04:35 PM   #10
Rewards Points: 125
Got a more accurate reading, it is 25. When the switch was replaced it was replaced with a generic brand. Currently waiting for a brand name to come in. Hoping that that is the problem.
Coleman Mobile Home Gas Furnace Problems Cberkimer HVAC 13 11-16-2014 07:51 PM
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 04:49 PM
Help me understand my furnace and home heating GalFriday HVAC 6 12-31-2010 05:26 AM
1895 Home door problems js1971 Building & Construction 7 09-04-2008 07:07 AM
Furnace Problems? MCSE HVAC 10 12-20-2006 11:06 AM
