-   -   home gas furnace problems (http://www.diychatroom.com/f18/home-gas-furnace-problems-166544/)
debd 12-15-2012 04:26 PM
In a home gas furnace sometimes the igniter glows and the gas kicks in the furnace igniting . Sometimes the igniter wont glow at all the furnace not starting. I have replace the electrical circuit panel/board and I have replaced the igniter. Why isn't the igniter glowing every time?
danpik 12-15-2012 05:09 PM
Is the draft inducer motor starting? If it is the pressure switch connected to it with a small vacuume tube may be bad. The ports on it also may be clogged. Next time the furnace won't start check to see if there is 24 volts on both sides of the switch on the pressure switch. Check this to ground. Sounds like this might be the problem.
Stubbie 12-15-2012 11:58 PM
Because something is telling the control board to not allow the igniter to light the gas and probably not allowing the gas to flow either.
What is the make and model of your furnace?
debd 12-16-2012 03:48 PM
Goodman
GDS 80703AXBB
debd 12-16-2012 04:25 PM
Yes, both post show full current. Does this mean the pressure switch is good or is there a change it is still bad?
danpik 12-16-2012 05:16 PM
What voltage did you see when you tested?
debd 12-16-2012 05:31 PM
Its reading 20 volts
danpik 12-16-2012 07:42 PM
Have you been able to get a reading when the furnace does not lite? 20 is a little on the low side but should work. Idealy 24+ is better.
NiNe O 12-16-2012 08:07 PM
20 volts is not enough, check the voltage across the pressure switch during the start of the heating cycle, should be 0, switch is closed, 24 and switch is open.
debd 12-21-2012 05:35 PM
Got a more accurate reading, it is 25. When the switch was replaced it was replaced with a generic brand. Currently waiting for a brand name to come in. Hoping that that is the problem.
