Home Electrical Wiring - FMC, NM And A Concrete Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 11-22-2013, 06:40 PM   #1
Home Electrical Wiring - FMC, NM and a Concrete Wall
Hello,
I want to add an outdoors outlet box for Christmas lights as well as my electric lawn mower and I have a question about how the wiring should be.
As you can see in the picture, I plan on adding a new 20 amp circuit breaker and running FMC from the panel to the new outlet which will luckily be just opposite the electrical panel. No more than a 6' run.
I also plan on having a switch in the middle of the circuit so I can turn off the Christmas lights at night but my question is how I should go from the wood in the basement through the concrete wall to outside.
I watched a video, , and saw how I could do it if I was tapping off of an existing outlet inside a room just using NM wires but in my case I want to make an entirely new circuit.
At first I planned on just running NM wiring from the circuit breaker panel to outside but from what I've read, the wiring needs to be protected if it's ran up the wall in my basement. If I plan on running such a short run, do I need to use FMC or would I be OK with NM wiring?
I know that this is a fairly simple job but I want to make sure it's up to code and safe.
So if I use FMC, my question is - how do I go from FMC in the basement through a concrete wall to the outside electrical receptacle box on the opposite side of the wall?
Should I find a giant drill bit that will bore a hole big enough for the FMC or can I strip back the metallic conduit and just have the wires themselves go through the concrete?
Any info, pictures or videos would be much appreciated as I'm striking out with Google and YouTube searches.
Thanks.
PS - I live in New Jersey and the house was built around 1955.
patjamesucf is offline   Reply With Quote
Old 11-22-2013, 07:02 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Why drill thru concrete? Go above the concrete wall and out thru wood.
You can not run NM outside, in conduit or not. If conduit the whole way use THWN wire. If only part conduit use UF cable.
Coastal South Carolina
Old 11-22-2013, 07:47 PM   #3
Going up and then through the wood has other issues I don't want to mess with.
So I'll definitely use THWN in the conduit but my question still remains - can I just cut back the conduit and have the THWN wire go through the bored tunnel in the concrete by itself without the conduit?
Old 11-22-2013, 07:52 PM   #4
Rewards Points: 330
no.single wires must be in conduit or raceway the whole way.you are going to drill a hole any just make it big enough for conduit.
oleguy74 is offline   Reply With Quote
Old 11-23-2013, 04:44 AM   #5
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by patjamesucf View Post
Hello,
Thanks.
how about a pic of the outside ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 11-23-2013, 08:29 AM   #6
Sure.
Old 11-23-2013, 09:29 AM   #7
A "Handy Husband"
rjniles's Avatar
Sure.
Can't see why you would even consider drilling thru that concrete when going above would be so easy. Even if that siding is asbestos.
Old 11-23-2013, 10:05 AM   #8
No, you're totally right. The wire won't be going through concrete. I was mistaken. I just bought the wiring and will be doing the install today.
Old 11-23-2013, 02:58 PM   #9
All done!
The Following User Says Thank You to patjamesucf For This Useful Post:
Philly Master (11-23-2013)
Old 11-23-2013, 04:12 PM   #10
Rewards Points: 516
LOL now if you only had a timer after the switch then you would not have to walk down each to turn off the lights ...
Old 11-23-2013, 04:31 PM   #11
Ah yes.. totally got that covered. I've ordered this guy and once it's installed, I can turn off the lights with my iPhone or set up a timer through the app :-)
http://www.amazon.com/gp/aw/d/B00DGE...ims_1?pi=SS115
Old 11-23-2013, 06:40 PM   #12
Rewards Points: 516
link does not really display correctly for me ..
Old 11-23-2013, 06:50 PM   #13
A "Handy Husband"
rjniles's Avatar
It is a remote control WIFI enabled switch.
Tags
code , concrete , electrical wiring , outdoors , wiring in basement
Mounting 60" LCD to thin concrete wall flatblackstrat Concrete, Stone & Masonry 7 02-18-2013 07:21 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 07:03 AM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 07:54 PM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 08:56 PM
